Author Topic: MAME DOS menu - ROMs highlighted in gray?  (Read 3187 times)
TxGlenn
  • Last login:June 03, 2015, 03:34:13 pm
« on: June 13, 2008, 10:21:17 am »
I'm using command line MAME 125u4 but I launch the .exe in windows.  When the game list pops up in DOS, some of the games are highlighted with a gray box...what does this mean?
I can't tell any status differences between those with and without the gray box and they both seem to play fine.
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
Re: MAME DOS menu - ROMs highlighted in gray?
« Reply #1 on: June 13, 2008, 12:05:51 pm »
DOS is often confused with command-line - the program is still running in Windows, just in a command box.  Anyway, the gray highlighted game name lets the user know that the set is not a parent set.  The built-in minimalist gui for MAME only accesses sets for which you have a .ZIP container showing in your rompath.
Hope that helps!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: June 13, 2008, 02:35:14 pm »
Err, nitpicking, but that list the OP mentioned is popping in as windows graphics, and has nothing to do with either DOS or commandline.
I'd say:
"DOS is often confused with command-line - mame is still running in Windows, just starting from a command box, and runs in a normal windows window (or full screen depending on settings), with a default font that looks DOS-like."
The default font, IMO, is arcade-like, and the dos font was arcade-like too, but that's too nitpickety even for me. ;)  Anyway, the default font can be changed, and to a more windows-like font if you want.
What he said. :)
Robin
Knowledge is Power
