I have fixed quite a few of these 7401s, but this problem is confusing me
The picture is fine, but is pushed off to the right about 3 inches. No amount of horizontal position change will fix it. If I adjust the horizontal sync POT, I can get it to normal size, but then the images becomes erratic.
I've replaced the:
* all caps and any cold solder joints (no change)
* tried a new tube/yoke (no change)
* replaced neck board (no change)
* replaced remote control board (no change)
* replaced U701 (no change)
Only thing left I can see is q800, but no one ever talks about that guy.
UPDATE - I replaced q800... no change. Maybe I have some random resistor that went down around the horiz sync/size area.
Any other suggestions?
