Author Topic: Possible help needed... arcade monitor  (Read 1509 times)
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« on: June 03, 2008, 06:19:39 pm »
I might be able to get this off ebay and use it for my new driving cab...
would mean that I'm restoring a project vs MAMEing it.
SHOTEN THOSE LINKS< DOGGONE IT!
Worth getting?  How easy is something like this to fix?
Is going into a Special Criminal Investigation cab, the car is
red, so I need to have red working.
Thanks for any help
« Last Edit: June 03, 2008, 07:09:40 pm by Peale »
grantspain
Re: Possible help needed... arcade monitor
« Reply #1 on: June 03, 2008, 07:05:37 pm »
thats a real old monitor,the red not working could be something as easy as a broken pot/bad solder joint or a drive transitor.on the other hand being so old it could be a tube gun dead-and that you ain't gonna fix
SirPeale
  • Green Mountain Man
« Reply #2 on: June 03, 2008, 07:11:36 pm »
If you could pick that up (and not have to ship it) and get it for *CHEAP* (I mean under five bucks) then do it just to get some experience under your belt.
Note that it's a Sanyo EZ which requires a 100 volt isolation transformer, not a regular 110V one.
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« Reply #3 on: June 03, 2008, 08:43:22 pm »
yup... did the same thing at an auction with a crt that was missing green.  Came with an entire dynamo cabinet for $25.
Ended up being the crt gun which was dead.  I tried to rejuvinate but she was too far gone.  I ended up buying a new monitor.
vidmouse
    • Vidmouse's Arcade
« Reply #4 on: June 04, 2008, 12:23:22 am »
Thanks, I'm more tempted now to get it, esp since I should be able
to pick it up close.
Here's another one the same guy has on sale, but there's
already a bid on it.  Wonder which one is better to get?
