Author Topic: Shakey image?  (Read 1518 times)
Angry_Radish
  • Last login:October 24, 2020, 06:36:17 pm
Shakey image?
« on: June 01, 2008, 03:09:15 pm »
Hi all,
I recently picked up a Neotec NT-2700 monitor that when first powered on has a shakey image, but stabilizes and looks great once it warms up.
Any thoughts on where to look first?
I figure I'll probably do a capkit eventually, but I wasn't sure if I should change anything else first.
grantspain
Re: Shakey image?
« Reply #1 on: June 01, 2008, 04:04:35 pm »
are you running this on 31khz?
Angry_Radish
Re: Shakey image?
« Reply #2 on: June 01, 2008, 05:14:53 pm »
Actually, I was under the impression it was a standard res monitor.
I haven't hooked it up to anything since I got it home, I just saw it running on the original cabinet (Samurai Showdown 64) before I pulled it. Is this a dual res?
grantspain
Re: Shakey image?
« Reply #3 on: June 01, 2008, 05:20:48 pm »
most likely general electrolitic failure then,i believe samurai showdown is snk neo geo 15khz-
Angry_Radish
Re: Shakey image?
« Reply #4 on: June 01, 2008, 06:05:17 pm »
Excellent, I'll just proceed with the capkit then.
