Author Topic: Program to create only horizontal .ini files??  (Read 1619 times)
Paladin
  • Mmmm llamaburgers!
« on: June 01, 2008, 12:22:54 pm »
I posted my dillema in the main section - I'm using a 25" arcade monitor mounted vertically, and the ArcadeVGA card.  I've used the resolution tool to create all the .ini files, but the problem is that although the vertical games all run fine, the horizontal games end up with differing amounts of the image cropped off the right side of the screen.
When I first set up my cab I only put about 300 games on it and manually set up all the horizontal games to this setting, and was perfectly happy with it:
hwstretch 1
effect sharp
resolution 288x640
I've just installed a complete ROM set, and newer version of MAME (.103) but I can't see myself going into every horizontal game to manually change it.   Would it be possible for someone to write up a quick program that creates an ini file for all horizontal games with the settings I listed above?
It seems like it would come in handy for anyone else with a vertically mounted monitor.  It also seems to me that the 'official' resolution tool should have the option to do this because there's already a check box for vertical or horizontal orientation.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: Program to create only horizontal .ini files??
« Reply #1 on: June 01, 2008, 05:00:36 pm »
I think you could do this with romlister.
http://www.waste.org/~winkles/ROMLister
1) create an ini file like you've described below, call it c:\horizontal.ini
2) kick off romlister, select batch file output.
3) in the batch file creation popup window, type "copy c:\horizontal.ini %rom%.ini"
4) do a search for all horizontal games only
5) save the output as a file
6) run the batch file from your mame folder.
It should copy horizontal.ini to a file named whatever rom name is needed.
this is all from the top of my head, so your experience may vary.
Paladin
« Reply #2 on: June 01, 2008, 08:11:31 pm »
Wow, that seems to have done the trick!  I've never used romlister before, but following the steps you laid out it created an ini file for each horizontal game with the same settings - just what I was looking for.
Thanks for the tip!
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
« Reply #3 on: June 01, 2008, 09:22:47 pm »
Great news Paladin.  Thank you, I'm going to try that.
