Author Topic: Just cut cabinet sides and they don't match exactly - need suggestions on a fix  (Read 2726 times)
Rocco
  • Last login:August 28, 2012, 12:47:57 am
Hi all,
I've been lurking here for awhile and tonight finally got started on my first MAME cab.  I cut both cabinet sides out of 3/4" MDF.  They came out pretty good (for a Noob), but don't match up exactly.  When I place the two pieces together, there are a few places where they are off by 1/16" or so, and one or two cuts are off by less than 1/8".  I thought I would clamp the two together and sand them until they are flush, but now I'm considering using a router with a pattern bit or flush trimming bit to get them to line up perfectly.  Does this sound like a better idea?  What do you guys recommend?
I appreciate any advice!  :cheers:
- Rocco
« Last Edit: June 01, 2008, 01:25:19 am by Rocco »
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
shiftybill
  • Last login:September 24, 2011, 09:09:35 pm
you should have clamped them while you were cutting them, but yeah clamp and sand them back
285,100 - Donkey Kong High Score
Rocco
I didn't think of clamping the two sheets together and cutting them at the same time...that would've saved  a lot of time.  Will the router method not work?  If I need to sand, I know I'll go through a lot of sand paper and it'll take some time to get everything perfect.  If that's the safest bet, what grit should I use? 80? And finish it up with 120?  I was hoping I could use a router and not have to sand for days...
Doctor Ugs
  • Last login:May 14, 2011, 02:56:58 pm
  • Arcade addict since 1980
flush trim bit is your best bet.
"My memory is so bad,
Alzheimer's would be an improvement!"
My Project Thread, 2 Mame Cabs.
Franco B
Yeah either a flush or pattern bit will work a treat.
Im guessing that one panel will be both bigger in some places and smaller in places than the other and vice versa. To end up with two sides exactly the same, clamp both sides together with the base and back of the cab sides flush and run your router around the profile. Then swap the two sides over (put the one on the bottom on the top) and run the router round again.
Jobs a good'en
JC
  • Last login:September 29, 2024, 04:15:39 am
Jobs a good'en
That worked amazingly well. Thanks everyone for your advice.
Cheers,
JC
Rocco
It sure did! Except for where I let the router base come off the wood when working one of the corners, the pattern bit worked great!  I'll be a woodworking pro when I'm done!
