Author Topic: Gorf restoration  (Read 140391 times)
Indus
  • Last login:April 07, 2019, 08:55:03 pm
Re: Gorf restoration
« Reply #240 on: April 07, 2019, 08:39:18 pm »
Hey guys, new to the forum... I just finished restoring a Gorf machine, including replacing the SC01 speech chip!   However, my joystick is pulling left... I put in a new grommit and cleaned the optical sensor etc.   No matter what I do I can't get the joystick to center.  Any suggestions?  I am completely stuck.
  • Last login:February 15, 2026, 01:44:40 pm
« Reply #241 on: May 19, 2019, 01:18:26 am »
It's been a while since I looked at mine, but if the plastic cover over the left optical sensor is scratched really bad it could potentially read as closed all the time.  It's either that or the left input wire is shorted somewhere.  The joystick is still just a digital 8-way, so it can't "drift" like an analog stick.
behrmr
  • Last login:April 23, 2021, 09:17:13 am
« Reply #242 on: May 19, 2019, 06:34:21 pm »
You probably need new optos. Also check for broken solder joints in the optical pcb especially the header pins. Make sure the header pins on the program pcb are clean not bent over.
matt_
  • Last login:December 16, 2020, 06:56:16 am
« Reply #243 on: October 01, 2019, 03:43:24 pm »
Hello guys, why cant see image anymore? :(
Spyridon
« Reply #244 on: October 10, 2019, 09:43:27 am »
Because Photobucket did a money grab and required payment to have your images viewable.
