Author Topic: Advice Needed - MAME'ing Virtua Striker Cab  (Read 1589 times)
iano
  • Last login:June 15, 2011, 03:39:11 pm
« on: May 28, 2008, 03:00:32 pm »
Hi. Just wondering if anyone has converted a Virtua Striker/Fighter Cab (late 90's). I've seen one in a warehouse and the cab looks in pretty good condition. I have two main concerns. 1.) The cab seems to be made of white laminated mdf - i don't mind it being white, i'm just wondering if i can somehow remove the sideart without damaging anything. 2.) What monitors are inside these cabs and will they be suitable for emulation/frontend use ? I haven't an actual photo of the cab as it was on a shelf way up high in the warehouse. Any advice would be appreciated. Thanks.
Havok
  • Trade Count: (+17)
Re: Advice Needed - MAME'ing Virtua Striker Cab
« Reply #1 on: May 28, 2008, 03:21:28 pm »
Should be just fine to Mame - they have a medium resoultion monitor, pair that up with an ArcadeVGA card from Ultimarc and you are good to go. Of course, I would also recommend AtomicFE for a front end choice...
iano
« Reply #2 on: May 29, 2008, 12:45:31 pm »
Thanks for the advice Havok. But i think on the frontend side of things i'll probably stick with GameEx (it's the only FE i've tried but i'm happy enough with it).
