Author Topic: mamewah custom lists?  (Read 2528 times)
Jox43w
  • Last login:May 22, 2009, 05:55:28 am
« on: May 27, 2008, 03:37:21 pm »
i run all my games in mame but i want to seperate the neogeo, cps1 2 and 3 titles into their own custom list with diffrent background. iv tryed putting the roms in a diffrent folder then generating a new games list but mame wont run unless they are in the mame roms folder and that way it just generates all the mame games any ideas?
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: mamewah custom lists?
« Reply #1 on: May 27, 2008, 03:47:57 pm »
you could try romlister to make the lists:
http://www.waste.org/~winkles/ROMLister/RomLister12beta2.zip
the mamewah stuff is beta, and I never got any feedback from anyone using it as to whether or not the lists would import properly into mamewah, so give it a shot and get back to me so I can release this pig.
I'd think you could just do a "neogeo" in the -find window to get a listing of all of them, then do a "!neogeo" to get a list of everything else.
I can help with the search criteria if you get stuck.
-jeff!
Jox43w
« Reply #2 on: May 27, 2008, 03:53:56 pm »
isit possible to search in mamewah? ill try romlister i might try running another copy of mame and put the neogeo games in and calling it neogeo in mamewah.
« Reply #3 on: May 28, 2008, 04:16:05 am »
You can create filtered lists in Mamewah...add an empty file called mame-1.ini into your \mamewah\config\mame folder - this will be populated when you run Mamewah.
Then in Mamewah, select this list (Select Games List) and go into Games List Options > Generate Filtered List.  Here you can use 'Bios Filters' to filter NeoGeo etc...
NOP: I will try RomLister and get back to you...
