Author Topic: Is there such a thing as a Classic MAME batch file to...?  (Read 1642 times)
jdsabin1
  • Last login:April 23, 2018, 09:22:45 pm
  • MAME - It's all about the gameplay.
In other words, a batch file that already has what can be defined as classic arcade games (Pacman, Donkey Kong, etc) that will simply delete all MAME roms EXCEPT those (or a variant thereof)? I just don't want to sort through thousands of ROMs to get that done.
Anything close would be cool.
Thanks all!
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Is there such a thing as a Classic MAME batch file to...?
« Reply #1 on: May 26, 2008, 11:30:05 pm »
You should be so lucky. There is a filtering tool that is mainly used for removing specific genres, but nothing so grand as what you're after. After all, who's to decide what's a classic and what's not? ???
Took me about a week, with several hours a night, to remove all the games I didn't want (non-working/mahjong/poorly emulated/other reason) by comparing my rom folder to the MAME32 list of games and rom names, then deleting all clones and such that appeared unnecessary according to MAME32's icons. Takes a while, but it's worth it.
jdsabin1
« Reply #2 on: May 26, 2008, 11:52:34 pm »
Yeah I understand the discrepancies relating to what the 'classics' are but I could have sworn a few years back someone gave it a go and created 'something'. At this point anything would be better than nothing and I just don't have the time to sift through them all.
NoOne=NBA=
« Reply #3 on: May 27, 2008, 12:31:21 am »
I think it would be easier to approach this from the "these are the games I want" side, rather than deleting them afterwards.
If all you add in are the games you want, that will be all that shows up.
The added benefit is that YOU get to decide what's a "classic".
Twin-X
  • Last login:April 26, 2018, 05:59:44 pm
  • Yes this avatar was stolen too!!!
« Reply #4 on: May 27, 2008, 08:13:27 am »
in mame32 there is a favorite list called "golden age" try that. you can export it and import it into the mala frontend if you like.
  • Last login:August 18, 2025, 07:06:41 pm
« Reply #5 on: May 27, 2008, 08:42:53 am »
I agree with this. It's a pain, but worth it. I've had to do it several times based on the type of game being built. I have several folders with different rom sets in each. 4 way, vertical and 1 button, 4 way, vertical  and 2 button, 8 way horizontal and 6 buttons.
Factor in PC's having different processing capabilities and I still have to thin down the list.
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #6 on: May 27, 2008, 10:07:31 am »
If you're using MAME32, you can select a favorites in the menu, and add whatever you want to it. That way, you can keep the others, if you ever decide to use them. That's how I have mine set up. I left off most of the variants of each game I had, and put the main one in favorites. But I still have them available if I decide I want to play one.
ahofle
    • Arcade Ambience Project
« Reply #7 on: May 27, 2008, 10:43:32 am »
You can use MCM to help remove some of the stuff like Mahjong and Quiz games:
http://www.mameworld.net/mcm/
Turnarcades
    • Turnarcades
« Reply #8 on: May 27, 2008, 12:08:10 pm »
That's the one I was thinking of. The named escaped me!
meany
  • Last login:May 01, 2019, 02:12:23 pm
  • Atomic batteries to power, turbines to speed....
« Reply #9 on: May 27, 2008, 12:48:19 pm »
This is what I do.  Just drag and drop into the Favorite folder.  I have about 150 in the Fav's that I consider Classic.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #10 on: May 27, 2008, 03:56:34 pm »
romlister too.
http://www.waste.org/~winkles/ROMLister
(sorry if I sound like a broken record plugging this)
it'll help weed down the full set to a list that supports only the controls you have on your cabinet, plus you can weed out the mahjongers and quiz games, and/or the matures and you could even add a "& 198" to the end of the search criteria to get only games from the 1980's, or perhaps
"& (1981 | 1982 | 1983 | 1984) to just get the "golden years"
ahofle
« Reply #11 on: May 27, 2008, 03:58:53 pm »
romlister too.
Wow that is very cool -- I'm glad you sound like a broken record because I missed your first few plugs. :)
Havok
  • Trade Count: (+17)
  • Last login:August 18, 2025, 12:44:57 am
« Reply #12 on: May 27, 2008, 10:36:01 pm »
romlister too.
Let me put my 2 cents in too - this is a great program - it can create native AtomicFE game lists, among others. Definitely a "must have" utility!
