Author Topic: T-molding Question  (Read 2558 times)
Vash
  • Last login:November 22, 2016, 03:31:09 pm
T-molding Question
« on: May 26, 2008, 01:57:20 pm »
I built my entire cab out of 5/8" MDF, and was planning on using orange t-molding, but I can't find the correct size in orange.  How hideous would 3/4" t-molding look on 5/8" MDF, and is there anything I can do to rectify this situation?
Jdurg
Re: T-molding Question
« Reply #1 on: May 26, 2008, 02:33:40 pm »
You can always use 3/4" T-Molding and a VERY sharp x-acto knife and a steady hand to trim off the excess.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
wbassett
  • Last login:October 05, 2024, 02:18:42 am
« Reply #2 on: May 26, 2008, 07:20:17 pm »
Trimming the excess is actually a breeze with a razor knife.  Just hold the blade flat against the cab and gently guide the blade.  T-molding cuts very easily.
For peace of mind, practice on a short piece.  Once you see how easy it is you won't have any concerns.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #3 on: May 26, 2008, 07:24:22 pm »
Rather than risk slicing the edges of your cab, route a short plank of 5/8 mdf out and feed it along that, trimming a bit at a time.
wbassett
« Reply #4 on: May 26, 2008, 09:17:34 pm »
I can say that I didn't have even the slightest problem of damaging the cab, but it was also made from LP Laminate, which isn't as tough as HP Laminate, but is more durable and tougher than paint.
Routing a 'trim board' though is excellent advice. :)
Bender
« Reply #5 on: May 26, 2008, 10:16:22 pm »
I did just that on mine (5/8 with 3/4 t-molding)
I used this veneer trimmer
worked great didn't damage the cab
quick and easy does both sides at the same time
you do have separate the sides or the inside hits stuff like the marquee and cp ect.
