Author Topic: FS: 48 white LED flexible marquee light - 48 cm long and works on 12V SOLD  (Read 2960 times)
Cero21
  • Last login:February 23, 2016, 11:04:44 pm
Hey everyone,
I recently picked up 2 of these for my arcade project and quickly realized 2 was overkill.  Buying 2 was, per unit, quite a bit cheaper than 1 so I figured why not?  Now that I realize I don't need the second so maybe someone else would like to take advantage of it.
This is a 48cm long LED strip that runs off 12V.  In total there are 48 bright white LEDs that light up a marquee fairly well.  To connect it to power I simply connected the 2 wires to a computer molex connector and plugged it into my computer power supply.
You can check out my lit marquee (using 1 strip) here:
http://forum.arcadecontrols.com/index.php?topic=78976.0
Here is a pic of the actual strip (sorry it's not lit).
$14 shipping included to anywhere in North America.  Shipping elsewhere will probably add a couple bucks.
« Last Edit: May 29, 2008, 06:59:06 am by Cero21 »
kagaden
  • Last login:September 10, 2022, 10:58:37 pm
PM Sent :D
Cero21
sold.
