Author Topic: Lock on controller?  (Read 1491 times)
Lilwolf
Lock on controller?
« on: May 25, 2008, 10:10:34 pm »
Is a lock-on controller the same as a starwars controller?  I'm looking for handles and one gear, and might have access to a lock-on controller, but don't have any pcitures to see if the internals are the same.
thanks!
NoOne=NBA=
Re: Lock on controller?
« Reply #1 on: May 26, 2008, 12:09:15 am »
I've got a Lock-on controller, and a friend of mine has a dedicated Star Wars, and I can't tell any difference between the two internally.
I haven't ever tried to exchange parts, but don't think it should be a problem for you.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #2 on: May 26, 2008, 05:02:11 pm »
I don't think the handles are quite the same.  Star Wars handles are angled so that the top of the handles point in towards each other; Lock-On (and Apache 3) handles point straight up & down.  I think they have the same diameter mounting holes, though, so you probably could use one or both Lock-On handles until you found a proper Star Wars one.  Look for an older Road Blasters controller for Star Wars handles; the early machines shipped with those instead of the blue plastic ones they used later.
NoOne=NBA=
« Reply #3 on: May 26, 2008, 07:19:38 pm »
Data East apparently had two different styles that they used.
Some of their machines used the Atari-style yokes, and others used the Tatsumi-style.
I don't think there was a real pattern to which game got what.
The pics below show two different Lock-on machines, each with the different style controller.
Kremmit
  • - AHOTW -
« Reply #4 on: May 27, 2008, 03:30:18 pm »
Either that, or the one in the bottom pic has had original parts replaced with Atari parts.  Either way, something to watch out for if you're after handles specifically.
NoOne=NBA=
« Reply #5 on: May 27, 2008, 07:28:30 pm »
Mine's exactly like that bottom one.
As near as I can tell from inspecting it, it shipped from the factory as-is.
