Author Topic: Do I have any style whatsoever? Part 2. The Control Panel  (Read 3208 times)
Cero21
  • Last login:February 23, 2016, 11:04:44 pm
« on: May 19, 2008, 06:00:10 pm »
Hi everyone,
UPDATED: 28 May
After successful critiquing of my marquee
http://forum.arcadecontrols.com/index.php?topic=78976.msg824001#msg824001
I am now working on my control panel.  Again, I appreciate and value any comments you might have.
Also, does the labelling make sense?  Do you think you would know what to do to exit based on the labelling alone???
The yellow circles are just placeholders for buttons/joysticks.
- Player start buttons are black
- The game buttons are yellow
- The admin buttons are red
- The trackball buttons are black.
Here is a pic of the cabinet with the marquee installed:
1)My CP Graphic
2)Second Iteration
Better?  Worse?  I decided to go against the 2 button exit to avoid confusion.
Changed the outlines around the joysticks too.
3) Blurred the gundam a bit, changed the opacity
4) Different gundam
« Last Edit: May 28, 2008, 08:22:23 pm by Cero21 »
Ginsu Victim
  • Comanche, OK -- USA
Re: Do I have any style whatsoever? Part 2. The Control Panel
« Reply #1 on: May 19, 2008, 06:25:01 pm »
The marquee turned out great. Glad to have been of service. Waiting to see this CPO...
Cero21
« Reply #2 on: May 19, 2008, 06:49:16 pm »
The image is up!  Blast away!  :)
ivwshane
    • My first mame cab! (WIP)
« Reply #3 on: May 20, 2008, 02:19:20 am »
Can you make the gundam bigger and centered?
Cero21
« Reply #4 on: May 26, 2008, 02:58:32 pm »
Done.  With some other modifications too!
Ginsu Victim
« Reply #5 on: May 26, 2008, 09:15:43 pm »
Oooo, now you can rub his taint.  :laugh2:
ivwshane
« Reply #6 on: May 26, 2008, 10:51:56 pm »
Was the gundam on the marquee just as detailed?
It looks good centered like that but you may need to tone down the detail.
Cero21
« Reply #7 on: May 28, 2008, 08:18:23 pm »
Yeah the marquee gundam is just as detailed.
Added CPs 3 and 4.
Comments?  If you think I'm way off course go ahead and tell me.  I can always start over if what I'm doin is junk.
ivwshane
« Reply #8 on: May 29, 2008, 01:42:50 am »
The last one seems to match a little better with the marquee.
Looks good to me.
