Author Topic: Identifying a Nanao MS9-29S component  (Read 4931 times)
UFighterX
  • Last login:July 14, 2008, 09:36:33 am
« on: May 18, 2008, 12:23:23 pm »
Does anyone know what this is so I can order a replacement? From what i've gathered it's either a thermistor or varistor but I have no idea how to find the specs. The circuit board says "NTH901" under it, while the actual component says "0S, 050, 4N" (Each comma represents a line change, I think they're zeros). I tried looking on DigiKey and Google but can't find any info.
Any help would be appreciated.
Thanks,
northerngames
  • Trade Count: (+18)
« Last Edit: May 18, 2008, 11:51:55 pm by northerngames »
Kevin Mullins
    • Me on Myspace
Re: Identifying a Nanao MS9-29S component
« Reply #2 on: May 19, 2008, 08:46:15 am »
Looks like the PTC thermistor component that controls the degauss coil.
grantspain
« Reply #3 on: May 19, 2008, 09:41:26 am »
joey at www.jomac.net.au will know the exact value of that component and a modern replacement,try emailing him as he is a nanao expert
Ken Layton
  • Guru
  • Technician
« Reply #4 on: May 19, 2008, 10:25:26 am »
These two components are used in the degauss circuit:
MCM Electronics # 33-650 Globar Thermistor
MCM Electronics # 32-7120 Thermistor posistor
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #5 on: May 19, 2008, 01:28:51 pm »
Here is a copy of that area of the circuits schematic. Hope it helps.
Good luck
Rick Nieman
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
UFighterX
« Reply #6 on: May 19, 2008, 06:18:37 pm »
Thanks for the info everyone. Very helpful :) I'll let you know how everything works out.
UFighterX
« Reply #7 on: June 05, 2008, 11:29:11 pm »
Replaced the parts that Ken Layton mentioned and everything is working great.
I think i'm finally done with this monitor. The colors were awful when I got it. Replaced the caps, then had to replace the parts mentioned. Just got finished tuning the colors and geometry. I'm finally happy with it.
Thanks again for the help.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: June 05, 2008, 11:38:25 pm »
Glad to see that it worked out for you.   :applaud:
