Author Topic: zsnesw key mapping question  (Read 2285 times)
reko19
  • Last login:July 16, 2025, 10:06:10 am
« on: May 16, 2008, 12:53:59 pm »
I am trying to figure out default mapping for the zsnesw so that I could program my IPAC accordingly. Default settings found in ziput.cfg are listed below. Some of the keys(i.e. 31, 30, 200, 208) do not correspond to any SDL key codes. What am I missing?
; Keys for Select, Start, Up, Down, Left, Right, X, A, L, Y, B, R
pl1selk=54
pl1startk=28
pl1upk=200
pl1downk=208
pl1leftk=203
pl1rightk=205
pl1Xk=31
pl1Ak=45
pl1Lk=32
pl1Yk=30
pl1Bk=44
pl1Rk=46
Ginsu Victim
  • Comanche, OK -- USA
Re: zsnesw key mapping question
« Reply #1 on: May 16, 2008, 01:51:56 pm »
have you tried just going into the GUI and setting them up? I set my Ipac up for MAME first, then just went into ZSNES and configured my controls in the GUI.
Guess I'm not sure what you're asking.
reko19
« Reply #2 on: May 16, 2008, 02:43:32 pm »
this is one way of doing it. i was going to set IPAC using default zsnesw key mapping and was trying to figure out based on config file what it is
unclet
« Reply #3 on: May 16, 2008, 04:04:26 pm »
It has been a while, but cant you simply start the zsnesw.exe (?) file and then go into the keyboard settings menu and see what the settings are set to .... instead of trying to decipher the INI file directly?
northerngames
  • Trade Count: (+18)
« Reply #4 on: May 16, 2008, 04:28:03 pm »
yeah your just making it more difficult for yourself for no apparent reason really  :dunno
set your ipac the way you want it and set eveythng else you want to use with your same ipac settings.
you kinda got it going backwards  :dizzy:
unclet
« Reply #5 on: May 16, 2008, 04:58:13 pm »
Actually I keep the emulator settings as default and simply reconfigure my encoder when I switch emulators.   This allows me to upgrade emulators with new versions without having to remember how to reset all the defaults manually every time.
Ginsu Victim
« Reply #6 on: May 16, 2008, 04:58:59 pm »
That's what I tried to tell him!  :dunno
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: May 16, 2008, 06:27:25 pm »
While it's easy to change each emu's inputs, if you keep updating it can be a PITA repetitive.  (One of the reasons I stopped releasing my own version of mame. :-\)  I understand the set and forget (even though I upgrade regularly) mentality.  Plus from the coding point of view I'm sort interested in what's going on: the numbers have to come from somewhere
Very quick skim of the source, looks like the windows version up, down, left, right (200,208,203,205) are VB/VC scancode numbers for the arrow keys, and the other OS compiles use different numbers for the direction buttons.  OTOH, all OS compiles use the same key numbers for the other inputs.  Too many different "scancode"s on google, hmm...
It almost looks like keynumber+1.  Err, like from the table on this page (plus one).  I think that would result in capslock, a, s, leftshift, z, x, slash and backslash?  (Easier for me just to download and test zsnes inputs... Nahhh, not at work. ;)
As others said, it's easier to remap in the emu, save the remapped inputs file somewhere, and just copy it to the new folder when you upgrade.
But if you want to do it your way, keep posting on what you find; I'll see it I can help even if others keep telling you to do it differently. :)
Robin
Knowledge is Power
Ginsu Victim
« Reply #8 on: May 16, 2008, 07:20:03 pm »
You know we don't think outside the box.
reko19
« Reply #9 on: May 16, 2008, 09:23:47 pm »
unclet was right. the easiest way is to enable GUI in zsnesw, go into config and check the key assignment. thanks everyone for chiming in.
« Last Edit: May 16, 2008, 09:26:34 pm by reko19 »
headkaze
  • 0x2b|~0x2b?
« Reply #10 on: May 18, 2008, 06:53:29 am »
They are DirectInput keycodes.
