Author Topic: MAME will not run full screen loading from front end  (Read 1339 times)
zmanpcxp
  • Newbie
  • Last login:May 11, 2008, 11:50:24 pm
« on: May 11, 2008, 10:02:04 am »
I am running MAME version .72. I am using it because it runs all of my roms. I have tried the mala and atomic front ends and whenever they launch MAME it is in a window. Whenever I drag the rom to MAME it runs in fullscreen, dragging the rom to MAME is equivalent to windows doing an openwith to MAME. Whenever I open a rom from command prompt MAME loads the rom in a window. I would like MAME to run full screen. Does anyone have a suggestion? your help would be greatly appreciated.
Thanks,
Zach
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: MAME will not run full screen loading from front end
« Reply #1 on: May 11, 2008, 01:11:53 pm »
Mame has a parameter in the mame.ini file that controls this.  I assume .72 is the same.  Edit mame.ini and change:
Code: [Select]
Window           1 to:
Code: [Select]
Window           0
