Author Topic: CPV2 help needed  (Read 1053 times)
reko19
  • Last login:July 16, 2025, 10:06:10 am
CPV2 help needed
« on: May 05, 2008, 09:41:10 am »
I am using it with Mamewah front end. Everything works great except that it displays "THIS GAME'S CONTROLS AREN'T DOCUMENTED" for most of the MAME games. I generated xml file and pointed to it thru CPV2 file setup utility.  What am I missing? Thanks.
I should add that when used from the command line i.e. cpv2.exe -r=frogger, it works fine
« Last Edit: May 05, 2008, 09:57:58 am by reko19 »
