Author Topic: fastmame 84  (Read 1588 times)
ablizno
  • Last login:August 15, 2011, 09:04:29 pm
  • [insert text here]
fastmame 84
« on: May 02, 2008, 09:09:14 pm »
IS there anyway to rotate the screen in fastmame. When i hit Tab durring gameplay i do not see the option to rotate the screen.
ablizno
Re: fastmame 84
« Reply #1 on: May 03, 2008, 11:58:53 am »
...can it not be done? Also how do i activate scanlines. I set the value to 1 and i still do not see them? Is there a place for me to specify the location of the scanline files?
Ginsu Victim
  • Comanche, OK -- USA
Re: fastmame 84
« Reply #2 on: May 03, 2008, 12:11:56 pm »
In the fastmame.ini
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
Set the appropriate number to 1
Just so you know, ror is rotate right, rol is rotate left. The autoror/autorol will rotate only for vertical games or vice versa.
For scanlines, I'm not sure because I use ddraw and they don't seem to work with that.
ablizno
Re: fastmame 84
« Reply #3 on: May 03, 2008, 12:13:21 pm »
thank you sooo much i will try it when i get home. So auto rotate....sounds nice... very nice.
any one else have any suggestions on the scanlines?
« Last Edit: May 03, 2008, 12:20:29 pm by ablizno »
ablizno
Re: fastmame 84
« Reply #4 on: May 03, 2008, 11:22:24 pm »
I got the rotating thing to work, thank you sooooo much :cheers:
if only i could get the scanlines showing up :timebomb:
