Author Topic: GameEx--Anybody use it?  (Read 1669 times)
danp
  • Last login:June 09, 2008, 01:51:42 am
« on: May 02, 2008, 11:02:56 am »
After researching the forums and different frontends, I think I want to use GameEx for my frontend.  I just wanted to post to see if anybody has any warnings or suggestions.  I will be running Vista, but have absolutely NO idea how to install my front end and run it, screen shots look pretty straight forward.  I'll be running every major console and MAME, probably Mame .124.
Has anybody run GameEx and experienced any problems?  My computer is expected to arrive tomorrow and I'm wanting to download everything I need today--is the process simply drag-and-drop, install, play?
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: GameEx--Anybody use it?
« Reply #1 on: May 02, 2008, 11:10:03 am »
Hi,
GameEX have a dedicated Forum, did you try to look at it?
http://www.gameex.info/forums/index.php?showforum=2
joebells
  • Last login:January 11, 2009, 07:57:45 pm
« Reply #2 on: May 02, 2008, 12:05:51 pm »
what exactly do you want from your frontend?
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #3 on: May 02, 2008, 12:21:04 pm »
I know that you are specifically asking about GameEx...  It's a good front end and fairly user friendly for the most part.
However, if you really want user friendly and kid friendly then I would highly suggest checking out Maximus Arcade.  I use it as my primary front end for right now and haven't had a single issue with it after I initially set it up.  Setup is a matter of navigating to the .exe for the mulator and pointing to the roms folders.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: May 02, 2008, 12:24:11 pm »
Have you consulted the Wiki page and looked at all of your options? Particularly the free ones?
http://wiki.arcadecontrols.com/wiki/Front-Ends
brian_hoffman
  • Last login:July 02, 2011, 09:02:20 pm
« Reply #5 on: May 02, 2008, 03:37:32 pm »
I use it.. Its very good and the support is awesome.
Give it a try:)
b00sted4fun
  • Last login:November 24, 2012, 08:28:16 am
« Reply #6 on: May 02, 2008, 03:39:28 pm »
I use it and love it.  one of the best things I have spent $ on in a long time
joebells
« Reply #7 on: May 02, 2008, 04:20:00 pm »
you might want to look at emucenter if your computer is coming with home premium or ultimate
danp
« Reply #8 on: May 02, 2008, 04:26:07 pm »
Hi,
Thanks for the link, I'm headed there now!  ;)
