Author Topic: Sega Naomi Power Supply  (Read 9843 times)
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
« on: May 01, 2008, 05:57:48 pm »
Any1 know how to rig a standard ATX power supply to power a Sega Naomi? I have seen pictures but haven't a clue  :dunno or a link where to purchase an adapter  :dunno
If You Are Going To Meddle At Least Listen
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Re: Sega Naomi Power Supply
« Reply #1 on: May 01, 2008, 10:15:43 pm »
why aren't you using the I/O board to power the Naomi?
DJ Infinity
« Reply #2 on: May 02, 2008, 02:23:01 am »
I don't have the Capcom I/O  :'(
Spaz Monkey
« Reply #3 on: May 02, 2008, 09:33:20 am »
On my system, the jamma harness connects into the i/o board.  The I/o board then connects to the naomi with a usb cable, rca jacks, vga cable and the power connector.  I think you need both for the system to work.
DJ Infinity
« Reply #4 on: May 02, 2008, 09:34:56 am »
I have no power connector but I have everything else :(
crzywolf
  • Last login:November 02, 2024, 10:15:06 pm
« Reply #5 on: May 02, 2008, 01:35:27 pm »
I have a ATX Naomi power cable you can have .
DJ Infinity
« Reply #6 on: May 02, 2008, 01:39:27 pm »
:woot :woot :woot :woot PM Sent
Spaz Monkey
« Reply #7 on: May 02, 2008, 09:07:05 pm »
Hold on here.  You said you don't have the i/o board, but now you do?
[link deleted because I didn't like how it screwed up the display of messages.  If you want to know what I'm talking about, look up "Naomi I/O" on ebay.com.  I'm talking about the silver thing in the pics.]
Here's a picture showing the I/O board.  Do you have that?
« Last Edit: May 02, 2008, 09:37:33 pm by Spaz Monkey »
DJ Infinity
« Reply #8 on: May 02, 2008, 09:17:35 pm »
You didn't read the post correctly, I said I don't have the Capcom I/O I have the JAMMA one  :) you know the low budget one. Now correct me if I am wrong I am still new to the NAOMI the Capcom one allows you to power the NAOMI correct? not the others.
« Last Edit: May 02, 2008, 09:24:02 pm by DJ Infinity »
Spaz Monkey
« Reply #9 on: May 02, 2008, 09:44:47 pm »
To my knowledge, the arcade power supply sends the volts to the I/O board by using the jamma harness.  The I/O board then powers the Naomi.  *My* naomi system  requires the i/o board.  If you can show me pics of a "jamma" i/o board, I will be glad to stand corrected.
DJ Infinity
« Reply #10 on: May 02, 2008, 10:59:31 pm »
here ya go.  :) this is what I have. The person I bought it from said I will need a power supply.
Another (#&^$($^&!!!! Shortened Link
« Last Edit: May 03, 2008, 05:29:02 pm by Peale »
Spaz Monkey
« Reply #11 on: May 03, 2008, 10:56:31 am »
Wow.  Interesting.  Does it have the VGA/USB/RCA jacks/hookups to it?
DJ Infinity
« Reply #12 on: May 03, 2008, 01:51:03 pm »
It has the VGA & USB hookup to it. But I am just gonna run the audio & video str8 outta the motherboard. What I don't know is a) where to plugin the kick harness b) what are the function of the other connectors on the I/O.  :dunno Any1 else with a NAOMI that has the el cheapo I/O board feel free to chime in and give me a hand  :cheers:
grantspain
« Reply #13 on: May 03, 2008, 03:32:39 pm »
the vga links to vga out of the naomi,this can be set to output either 31khz or 15khz on dil switch position 1 of the naomi mobo
the usb is not usb,its sega adaption
http://www.sauservice.com/manuals/KITS/NaomiWD.pdf
your video can run direct from the mobo as either 15k or 31k but the audio needs to go via an amp
grantspain
« Reply #14 on: May 03, 2008, 03:34:30 pm »
DJ Infinity
« Reply #15 on: May 03, 2008, 04:48:10 pm »
I don't think I need a sound amp. Reason being I have powered speakers in the cab so all I should have to do is adjust volume accordingly. Unless the sound output is equivalent to that of a turntable. In that case a spare reciever I have laying around will do the job.
