Author Topic: Desperate Trouble Shoot help with Factory CarnEvil Arcade  (Read 3618 times)
StripHouseBandit
  • Last login:May 01, 2008, 06:35:01 pm
« on: May 01, 2008, 05:51:54 pm »
I've been looking desperately for someone to help me with this, but there seems to be no forum that i can find that can help me with the answers.. if you know of one please send me a link.... (ice also tried going to arcade rooms to fget incontact with an arcade machine mechanic...but no luck) .. i have an original factory made carnevil arcade machine, it's NOT a mame project...i dont know much about  it, but it seems to have a very minor issue...maybe some of you know what it is and its just a minor fix, during game play, whenever i pull the triger, it just reloads, the trigger and pump works fine...i thought the guns just simply need to be recaliberated, but whenever i aim it doesnt seem like the signal from the optical lens is reading to the screen, isometimes...maybe one out of every 100 trigger pullls it will register a shot on screen at exactly where im aiming....can it be a bad connection?...do i need new guns? any help or directory in help would be appreciated, thanks
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
Re: Desperate Trouble Shoot help with Factory CarnEvil Arcade
« Reply #1 on: May 01, 2008, 06:26:11 pm »
Are the lenses dirty?  Gun might need a good cleaning perhaps
StripHouseBandit
« Reply #2 on: May 01, 2008, 06:35:01 pm »
i thought that was it too... the whole arcade machine IS pretty dusty..and hasnt been played much.. but i took a dry cotton swab to the outside lense.. perhaps i have to clean it on the inside as well?...the problem IS with both guns ...,,does that happen sometimes with dirty lenses?
SirPeale
  • Green Mountain Man
« Reply #3 on: May 01, 2008, 08:07:50 pm »
Make sure your monitor is clean.  And mirror, if so equipped.  Same with your bezel (the glass covering the monitor area).
Look at the lens on your gun.  Is it dirty?  You may want to disassemble the gun and clean it.  Yes, both sides.  Also check the gun PCB.  There is a sensor pointing out towards the barrel.  Sometimes the solder joint on it breaks.  If it has, resolder it.  If it's totally broken off, you may need a new PCB.
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #4 on: May 01, 2008, 08:57:07 pm »
Along with the stuff others have mentioned, you may want to try turning up the brightness on your monitor.  Also, check the 5 volts at your game board.
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #5 on: May 02, 2008, 10:21:05 am »
Also check the alignment of the stars.  They might just be against you.   :dunno
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
