Author Topic: Has MALA development stopped?  (Read 5397 times)
TheBrokentoken
  • Last login:December 13, 2009, 09:19:37 am
  • Being a noob is awesome! (not)
    • Brokentoken.com
« on: April 29, 2008, 09:14:23 pm »
Just curious
I'm a happy user of the current version (released August 2007) but I've not heard a single thing about a refresh build or 64-bit compatibility.  It seems that many on here on BYOAC are switching to 64-bit OS's and versions of MAME and MALA doesn't work like it should.
Any news from anyone in the know?   TIA.
- Whitney Roberts
http://www.brokentoken.com
joebells
  • Last login:January 11, 2009, 07:57:45 pm
Re: Has MALA development stopped?
« Reply #1 on: April 30, 2008, 01:15:57 am »
loadman(not the developer but they have a connection of some sort) said development will be picking back up at some point.
loadman
  • Moderator
    • MaLa
« Reply #2 on: April 30, 2008, 03:37:30 am »
Indeed  ;)
TheBrokentoken
    • Brokentoken.com
« Reply #3 on: April 30, 2008, 09:58:44 am »
OK,
thanks for the replies guys.  I really like MALA a lot (as I know many others here on the forum do, as well).  I just want to see it rise to the current challenges and continue to move forward.
- Whitney Roberts
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: May 11, 2008, 05:25:12 am »
Me and loadman just discovered MaLa will work fine in Mame64 if you delete MaLaKeyHook.dll from the MaLa folder :)
loadman
  • Moderator
    • MaLa
« Reply #5 on: May 11, 2008, 06:55:25 am »
Thanks HeadKaze for confirming this   :cheers:
I don't have a 64 bit OS to test this... yet? Anyone want to donate one?   ;D
http://forum.arcadecontrols.com/index.php?topic=79974.0
« Last Edit: May 11, 2008, 07:43:13 am by loadman »
headkaze
  • 0x2b|~0x2b?
« Reply #6 on: May 11, 2008, 08:05:23 am »
Do you have a 64-bit processor to run it on?
loadman
  • Moderator
    • MaLa
« Reply #7 on: May 11, 2008, 08:16:11 am »
Well my PC at home is a AMD64 AthlonX2 dual core.
I don't want to blow away my OS so I will be loading it using a Vitual enviroment.
Will that work?
headkaze
  • 0x2b|~0x2b?
« Reply #8 on: May 11, 2008, 08:18:10 am »
Will that work?
No it won't work if your running a 32 bit OS. In fact AFAIK most virtual PC software like Virtual PC and VirtualBox don't allow you to run 64-bit OS even if your real OS is 64-bit.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #9 on: May 11, 2008, 02:20:51 pm »
Headkaze,
My version of VMWare Workstation Ace (6.02 build 59824) has 64 bit O/S listed though I haven't actually tried them.  See screenshot:
headkaze
  • 0x2b|~0x2b?
« Reply #10 on: May 12, 2008, 02:34:10 am »
I don't think any of the free ones can though (yet anyway)
loadman
  • Moderator
    • MaLa
« Reply #11 on: May 12, 2008, 03:00:24 am »
I can probably get vmware (via work) if someone can donate a 64 bit os  :-)
