Author Topic: anyone else having issues with shareaza?  (Read 2162 times)
gavkiwi
  • Last login:October 12, 2021, 08:42:07 pm
  • 'I am from a Land Down Under'
« on: April 29, 2008, 05:39:22 pm »
So, Ive been using shareaza for a long time now, its great for torrents.
until this morning that is, my download status shows 'pending'
and if I goto the connections settings, it says im not connected  :badmood:
I tried different conenction settings, no go, didnt help
so, anyone else having this problem?
if not, anyone got any good alternatives to shareaza?
cheers
lokki
  • Last login:May 05, 2025, 06:18:51 pm
Re: anyone else having issues with shareaza?
« Reply #1 on: April 29, 2008, 08:36:04 pm »
I use Utorrent for bittorrents and shareaza for eDonkey and Gnutella.
perform a Connection test. Firewall settings could have changed.
gavkiwi
« Reply #2 on: April 30, 2008, 12:08:00 pm »
I have Kaspersky AV, I disabled the firewall, then tried the shareaza app, didnt help.
So to me, does not appear to be a firewall issue, I think I'll use a diff program  :-\
shardian
« Reply #3 on: April 30, 2008, 01:09:05 pm »
Azureus
gavkiwi
« Reply #4 on: April 30, 2008, 01:23:41 pm »
thanks I'll check out utorrent and azureus  :angel:
lokki
« Reply #5 on: April 30, 2008, 02:32:59 pm »
I assume you mean you disabled the routers firewall.
(the connection test should tell you if it is having firewall issues).
Look under Help Connection Test
Also you may want to try and change the port used
Tools-Shareaza settings-Internet-Connection
gavkiwi
« Reply #6 on: April 30, 2008, 02:59:30 pm »
cool, thanks for the info lokki, ill check it out when I get outta work  8)
ark_ader
  • I glow in the dark.
« Reply #7 on: May 01, 2008, 03:33:43 am »
Your ISP probably have blocked all your P2P ports.
Its not a good sign.
You might get a knock on the door from the Feds.
Nuke your hard drives.
:police:
gavkiwi
« Reply #8 on: May 01, 2008, 07:03:22 am »
um, I dont think so  ;D
I tried utorrent & Azureus, they worked fine
then I installed shareaza 2.3.1, tested my connection, said it was firewalled, the old version never said that
I disabled the firewall, then turned it back on while the program was active, soo far soo good  :cheers:
AtomSmasher
    • Atomic-Train
« Reply #9 on: May 01, 2008, 10:07:50 am »
I used to use Azureus, but it was always crashing on me, so I switched to Bit Torrent
shardian
« Reply #10 on: May 01, 2008, 10:21:37 am »
Rule of thumb for Azureus, decline their updates. If it ain't broke, don't fix it. I allowed their updates once and the prog never worked again on that PC.
