Author Topic: Jen Shinn  (Read 2567 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
Jen Shinn
« on: April 26, 2008, 10:12:12 am »
is anyone here using a Jen Shinn chassis i want to know do it has contrast control
Ken Layton
  • Guru
  • Technician
Re: Jen Shinn
« Reply #1 on: April 26, 2008, 11:21:33 am »
Depends on model and tube size. Some do, some don't.
alienware32
Re: Jen Shinn
« Reply #2 on: April 26, 2008, 11:24:10 am »
I'm going to try there 27 inch i have a we ya chassis it alright  i just don't like the blooming issue
grantspain
Re: Jen Shinn
« Reply #3 on: April 26, 2008, 12:46:03 pm »
is it doing the blooming when the screen changes??
alienware32
Re: Jen Shinn
« Reply #4 on: April 26, 2008, 02:21:44 pm »
yes whenever the screen changes
grantspain
Re: Jen Shinn
« Reply #5 on: April 26, 2008, 03:29:55 pm »
it is the ABL adjustment(automatic beam limiter) is not set correctly,the chances of getting it right are slim but worth a go
monitor manufacturers would set this using some very special equipment
alienware32
Re: Jen Shinn
« Reply #6 on: April 26, 2008, 04:06:25 pm »
how do you adjust it
grantspain
Re: Jen Shinn
« Reply #7 on: April 26, 2008, 04:49:08 pm »
well depends on the chassis,if you have one with an ABL pot you can do it with that
if your chassis does not have this pot then its component changes but this is a little out of my league,i would think rickn knows the score on this
basically your chassis is not that well matched to your tube/yoke config
what chassis model do you have btw?
alienware32
Re: Jen Shinn
« Reply #8 on: April 26, 2008, 04:51:45 pm »
i have a wei ya 826hr it ok for the most part think ill try the jen shinn
grantspain
Re: Jen Shinn
« Reply #9 on: April 26, 2008, 05:00:58 pm »
worth a go i guess,maybe you will get a better match
i am doing some tests on rodotron chassis next week,i am tri syncing a nanao ms9-should be quite interesting to see if i can match the chassis perfectly
good luck with yours
