Author Topic: mamewah question: Remove game from list  (Read 1923 times)
Ginsu Victim
  • Comanche, OK -- USA
« on: April 25, 2008, 09:26:54 am »
Does "remove game from list" only work with custom lists? I've never used a custom list, and I can't remove any games without manually editing the emuname-0.lst
massive88
Re: mamewah question: Remove game from list
« Reply #1 on: April 25, 2008, 09:40:28 am »
Its just for custom lists I beleive.
Is there a way to hide the "All Games" list-0?
Ginsu Victim
« Reply #2 on: April 25, 2008, 09:57:39 am »
Also, any way to filter out mature titles? I've got some friends coming over and their kids are going to be playing.
« Reply #3 on: April 25, 2008, 10:21:10 am »
Yes it is just for custom lists (the main list is used to create custom lists, when using filters).
The main list cannot currently be hidden, although by setting cycle_list 0 in it's ini file, can be avoided if using the next/previous list shortcuts.  Someone else just requested an option to hide this list, I am going to try to do it for the next release.
« Reply #4 on: April 25, 2008, 10:21:39 am »
Use catver.ini, and use the Category Filters to get rid of them.
Ginsu Victim
« Reply #5 on: April 25, 2008, 10:37:49 am »
Having never messed with catver.ini or the category filters, that's russian to me.
massive88
« Reply #6 on: April 25, 2008, 11:06:01 am »
That would be cool, to allow for maintaining complete rom sets, but not overwhelming non-initiated users with massive Mahjong lists.
If Cycle list 0 does the trick, that seems like it would work fine as long as you navigate off it before anyone uses it right?
« Reply #7 on: April 25, 2008, 12:17:52 pm »
1) OK, you need to download catver.ini, preferably corresponding to your Mame version. I used to get it from: http://www.mameworld.net/catlist/ .  Note that this version hasn't been updated for a while...I use Mame 0.99 so I haven't bothered to see if anyone else make an updated version, but I expect a search would fine someone probably has.
2) Place catver.ini in your Mame folder and point to it in your mamewah mame.ini file, eg:
catver_ini_file                           c:\mame\catver.ini
3) Refresh your main games list (the category info will then be picked up)
4) Go into a custom list (any list other than 'All Games'), and go into Games List Options > Generate Filtered List...  At the bottom of this submenu will be Category Filters - select that and things should become obvious at this point. Back out of the menu and your list will be filtered accordingly.
« Reply #8 on: April 25, 2008, 12:18:48 pm »
Yes. BUT, if you use the 'Select Platform' menu then it will still be visible in that list.
Ginsu Victim
« Reply #9 on: April 25, 2008, 02:55:26 pm »
Thanks minwah. You're awesome.
Luckily, I use Mame .84, so finding the catver.ini on that site was no problem.
I understood where it went in the mame.ini, I just didn't know how to use it in mamewah. Thanks for the info.
The more I use mamewah, the more I love it.
