Author Topic: Pros and Cons of PSP CFW?  (Read 7238 times)
BCThunder
  • Last login:May 27, 2017, 06:07:23 pm
« on: April 21, 2008, 02:30:00 pm »
Hey all.  I've recently gotten a PSP (Daxter Bundle).  I've been doing research on all the options for custom firmware, Pandora's Battery, and all of that.  I'd be interested in running emulators (SNES, Genesis, etc), but worried about turning my new toy into a brick.  Are there any disadvantages to going to custom firmware?  Would I be missing out on any features the official firmware would give?  Is it easy to move to and from custom to official if needed?
Re: Pros and Cons of PSP CFW?
« Reply #1 on: April 21, 2008, 06:29:03 pm »
with a pandora battery you cant brick it.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #2 on: April 21, 2008, 06:32:20 pm »
I'm sure some people will have an answer or two, but you'd be better enlightened by finding boards that focus on this sort of thing, or doing some research on the topic with google.
I imagine as long as you do it right and you have a good version of the psp, you shouldn't have any problems.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
pointdablame
« Reply #3 on: April 21, 2008, 07:59:26 pm »
There are no downsides and the chance of bricking it is VERY slim -- its much more likely you'd drop it or something before you bricked it trying to upgrade your firmware.
first off your and idiot
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #4 on: April 21, 2008, 10:49:31 pm »
I've done about 10 PSPs so I can help.
No there are NO cons basicly.  Why?  Cause you can put custom firm ware on your PSP and then NEVER use it as more than a normal PSP, never use a pirated/backed up game, and it will all still work.  You could give most people a CFW PSP and they wouldn't know it's modded.
The tools used to flash a PSP are basicly the same tools Sony uses in the factory to bypass the firmware on the flashrom and run tools to unbrick it.  So you're using unbricking tools to mod your PSP, if you brick it in the process, you just start over agian and unbrick it.  The only way you can HURT your PSP running the pandora tools is to DROP it while you're doing it.  ...Don't do that.
There is one minor issue to considder however.  CFW allows you to access the flash rom space and alterate if you want to, if you don't have your own pandora/unbricking tools in there, you could mess around in there and brick your PSP and have to go find someone to fix it for you.  But you should NEVER have a reason to go in there in the first place.  Just don't. :o
