Author Topic: Mortal Kombat 2 cab  (Read 3909 times)
MadGamer
  • Last login:February 02, 2019, 10:40:51 am
  • Locotestman
Mortal Kombat 2 cab
« on: April 20, 2008, 06:07:07 pm »
Ive just started on my MK2 Mame conversion and I need help picking a monitor Ive read a bunch of topics on the subject but i just Get confused. I want to use whatever is the easyest to install configure
I haven't bought anything yet so I'm just starting my list.
« Last Edit: April 20, 2008, 06:26:18 pm by MadGamer »
I used to be Knowledgeable !!
Re: Mortal Kombat 2 cab
« Reply #1 on: April 20, 2008, 06:11:23 pm »
factory MK2s have 25" hanatrex polo monitors.  if you have nothing there easiest to configure would be a 25" PC monitor
MK3FAN
« Reply #2 on: April 20, 2008, 07:01:16 pm »
Below you will find a link to the monitor that I have in 3 of my 4 Mortal Kombat cabs. They are relatively cheap and I am very pleased with them....
http://www.wgec.com/products/details.asp?iCat=3&iSubCat=2
MadGamer
  • Locotestman
« Reply #3 on: April 24, 2008, 06:37:06 pm »
Is there a certain monitor that you can get the doesn't need any adjustment after initial setup?
MK3FAN
« Reply #4 on: April 24, 2008, 08:30:42 pm »
Once you get pretty much any monitor and adjust your focus, color, etc. it shouldn't need adjusting for quite some time.
MadGamer
  • Locotestman
« Reply #5 on: April 27, 2008, 05:12:17 pm »
Its no longer available what would be similar.
MK3FAN
« Reply #6 on: April 27, 2008, 06:59:47 pm »
Did you call to see if they have any left. Discontinued just means they aren't making them anymore. There still may be some available.
MadGamer
  • Locotestman
« Reply #7 on: May 06, 2008, 07:31:27 am »
Does anyone know if you can fit a d9400 into a mortal kombat 2 midway cab.
TOK
  • The Game Always Wins
« Reply #8 on: May 06, 2008, 04:17:46 pm »
If you look closer at the link, the 25" monitor on the right is no longer available. They replaced it with the 24.8" version on the left to get around the government requirements for 25" and larger tubes.
