Author Topic: Mamewah is not finding my roms  (Read 3933 times)
jordya
  • Last login:February 14, 2010, 07:34:14 pm
« on: April 18, 2008, 01:45:41 am »
Hello,
I apologize if this has been asked many times before, but I've read and followed many posts and tutorials and I am still unable to locate my roms using mamewah. After setting up Mamewah, it comes up with No Games Available.
Some backround:
Mame.exe is installed in C:\mame
The roms are in C:\mame\roms
When I open mamewah, I press 2, click on Games List Options, then Generate List. It works for a second, but still nothing on the list. It even says "No Games Available."
I thought maybe the roms were bad, so I downloaded some official roms from mame.net. They are not listed as well.
I am assuming something is incorrect with the rom location setup in mame.ini. Here is the mame.ini settings:
rom_path c:\mame\roms
rom_extension zip
dat_file
nms_file
catver_ini_file
list_generation_method rom_folder_vs_listinfo
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline c:\mame\mame.exe [name]{nodosbox}
post_emulator_app_commandlines
general_app_commandlines
Any help or advice is greatly appreciated. thank you again.
Jordy Anderson
jordya
Re: Mamewah is not finding my roms
« Reply #1 on: April 18, 2008, 02:02:07 am »
Here is my full "mame.ini" in mamewah
### mame.ini (mamewah v1.62) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_extension                             zip
dat_file
nms_file
catver_ini_file
### Artwork Settings ###
artwork_image_paths                       c:\mame\snap;c:\mame\marquees
movie_preview_path                        c:\mame\previews
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
« Reply #2 on: April 18, 2008, 04:39:08 am »
If you are using a version of Mame >0.83, then change this to:
list_generation_method                    rom_folder_vs_listxml
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: April 18, 2008, 08:16:02 am »
Also, make sure the INI in the MAME program folder (not in MameWAH, but the actual MAME itself) is pointing at your roms.
jordya
« Reply #4 on: April 18, 2008, 10:33:12 am »
Thanks for the fast reply.
I changed "rom_folder_vs_listinfo" to "rom_folder_vs_listxml"...it actually started to look for roms. Hooray!. However, now I get the following error:
Program Error!
An internal error has occured - see c:mamewah_1.62B13\mamewah.log for details
Here is the log file:
4/18/2008 9:25:30 AM MAMEWAH v1.62 launched
4/18/2008 9:25:30 AM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
4/18/2008 9:25:30 AM Desktop colour: 0
4/18/2008 9:25:30 AM Wallpaper filename: C:\Documents and Settings\Jordy Anderson\Application Data\Microsoft\Internet Explorer\Internet Explorer Wallpaper.bmp
4/18/2008 9:25:30 AM Desktop display mode: 1280x1024 @ 60Hz, 32bit colour
4/18/2008 9:25:30 AM Decimal symbol: '.'
4/18/2008 9:25:30 AM Games list read: mame-0.lst
4/18/2008 9:25:32 AM Mode 800 x 600 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
4/18/2008 9:25:32 AM Layout selected: C:\MAMEWAH_1.62B13\config\mame\\layout.lay
4/18/2008 9:25:33 AM No. joystick devices attached: 0
4/18/2008 9:25:33 AM Ctrlr file selected: C:\MAMEWAH_1.62B13\config\mamewah.cfg
4/18/2008 9:25:33 AM Keyboard enabled
4/18/2008 9:25:33 AM Mouse enabled
4/18/2008 9:25:38 AM List generation started...
4/18/2008 9:25:38 AM Current drive/directory selected: c:\mame
4/18/2008 9:25:38 AM Commandline run: C:\WINDOWS\system32\cmd.exe /c c:\mame\mame.exe -listxml > C:\MAMEWA~2.62B\mame.xml {flags=81}
4/18/2008 9:25:59 AM Application quit: C:\WINDOWS\system32\cmd.exe /c c:\mame\mame.exe -listxml > C:\MAMEWA~2.62B\mame.xml
4/18/2008 9:26:06 AM Error: 70 Permission denied in GenerateList
4/18/2008 9:26:06 AM Games list read: mame-0.lst
4/18/2008 9:26:24 AM List generation started...
4/18/2008 9:26:24 AM Current drive/directory selected: c:\mame
4/18/2008 9:26:24 AM Commandline run: C:\WINDOWS\system32\cmd.exe /c c:\mame\mame.exe -listxml > C:\MAMEWA~2.62B\mame.xml {flags=81}
4/18/2008 9:26:42 AM Application quit: C:\WINDOWS\system32\cmd.exe /c c:\mame\mame.exe -listxml > C:\MAMEWA~2.62B\mame.xml
4/18/2008 9:26:49 AM Error: 70 Permission denied in GenerateList
4/18/2008 9:26:49 AM Games list read: mame-0.lst
4/18/2008 9:27:03 AM List generation started...
4/18/2008 9:27:03 AM Current drive/directory selected: c:\mame
4/18/2008 9:27:03 AM Commandline run: C:\WINDOWS\system32\cmd.exe /c c:\mame\mame.exe -listxml > C:\MAMEWA~2.62B\mame.xml {flags=81}
4/18/2008 9:27:21 AM Application quit: C:\WINDOWS\system32\cmd.exe /c c:\mame\mame.exe -listxml > C:\MAMEWA~2.62B\mame.xml
4/18/2008 9:27:28 AM Error: 70 Permission denied in GenerateList
4/18/2008 9:27:28 AM Games list read: mame-0.lst
4/18/2008 9:27:38 AM Mode 1280 x 1024 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
4/18/2008 9:27:40 AM MAMEWAH quit
Also, I checked the .ini in the MAME program folder and it is pointing to my roms.
Thanks again for the assistance.
Ginsu Victim
« Reply #5 on: April 18, 2008, 10:42:29 am »
forgive me if this is a stupid question, but you never know sometimes.
Your ROMs are still zipped, right?
« Last Edit: April 18, 2008, 11:03:50 am by GinsuVictim »
jordya
« Reply #6 on: April 18, 2008, 10:54:37 am »
yes they are still zipped.
jordya
« Reply #7 on: April 18, 2008, 06:04:49 pm »
Ok, I finally got it working. I had to change back to "rom_folder_vs_listinfo and then install Mame 0.82.
If I want to install a more current version of MAME, what should I do to get MameWah to work with it..."LISTXML" did not seem to work with any version of MAME I tried.
thanks again
gonzo90017
« Reply #8 on: April 19, 2008, 12:26:41 pm »
Download the dat file for the mame version you're using from here. Make sure you download the (cm) version. Unzip it inside your mame folder. Then change the list generation method to
Code: [Select]
rom_folder_vs_dat_file. And point to the dat file.
Code: [Select]
dat_file                                  C:\juegos\mame37\MAME v0.37b16.dat
« Reply #9 on: April 21, 2008, 04:23:03 am »
Download Mamewah v1.62final from mamewah.mameworld.net - there were some list generation problems with b13.
jordya
« Reply #10 on: April 23, 2008, 04:32:15 pm »
Code: [Select]
Code: [Select]
Ok, I changed the mame.ini file to this:
dat_file                                  c:\mame\dat\MAME v0.84
list_generation_method                    rom_folder_vs_dat_file
I downloaded "MAME v0.84 (cm)" and unzipped into c:\mame\dat
started up Mamewah...no games will list.
So to summarize:
list_generation_method                    rom_folder_vs_listxml (works)
list_generation_method                    rom_folder_vs_dat_file (does not work)
list_generation_method                    rom_folder_vs_listinfo (does not work)
jordya
« Reply #11 on: April 23, 2008, 04:39:37 pm »
I tried the same thing with Mamewah v1.62...same results
gonzo90017
« Reply #12 on: April 23, 2008, 05:23:18 pm »
You forgot to put the extension for the dat file.
Code: [Select]
dat_file                                  c:\mame\dat\MAME v0.84.dat
jordya
« Reply #13 on: April 24, 2008, 09:04:43 am »
Code: [Select]
Hooray! It is working.  :cheers: Thank you very much.
