Author Topic: Paint for shiny finish?  (Read 1686 times)
Retro_SA
  • Last login:July 12, 2010, 08:38:17 am
« on: April 16, 2008, 08:08:03 am »
What paint should I use to get a shiny finish on my cabinet?  Or doesn't it matter as long as you sand it down between coats?  It's a mdf cabinet and I want to paint it black.
  • Last login:Today at 01:14:34 pm
Re: Paint for shiny finish?
« Reply #1 on: April 16, 2008, 09:40:45 am »
How much work are you willing to put in?   >:D
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #2 on: April 16, 2008, 11:08:46 am »
You can top coat with high gloss polyurethane if you like, it'll be *very* shiny :)
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #3 on: April 16, 2008, 11:23:03 am »
Just go to your local Sherwin Williams, and ask for a gloss, to a high gloss. If you prime it first, it should only need one coat of paint.
Yarb
  • Last login:December 26, 2019, 01:18:30 pm
« Reply #4 on: April 16, 2008, 12:54:42 pm »
I used automotive paint and clear coat and it's shiny, REALLY shiny  8)
Yarb
RoninEditor
  • Last login:April 14, 2009, 02:46:58 am
« Reply #5 on: April 17, 2008, 03:32:43 am »
I'm using the Rustoleum (sp?) Latex Enamel High Gloss - Black.  I love it so far, matches EXACTLY the texture of my over/under Happ coindoor.  It's definitely shiny but has a subtle texture to it.
I have two layer of primer and three coats of the above-mentioned paint, sanding with 400 grit for the first two layers, 600 grit for the last three black ones.
Someone mentioned using just one coat... personally, I disagree... if you want it done right, you need at least two coats, three to be safe.  You want all of the gaps covered... this hobby isn't cheap so do it right, ya know?  It's a bee-yotch to do and is extremely time-consuming, but you'll thank yourself for not rushing it.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #6 on: April 17, 2008, 03:45:39 pm »
i painted some woodworking projects, including control box with a piano finish.
the best way to do it is with a spray finish. I use an hvlp automotive touch up gun.
real briefly...
start with automotive primer
spray heavy and thick
sand smooth up to 600 grit
spray more primer
sand again
spray color
spray hardened clear coat
sand up to 2000 grit
hand polish with compound.
Jdurg
« Reply #7 on: April 18, 2008, 09:47:26 am »
You know, in some cases having a few brush marks or "not-smooth" areas may add some character to a cabinet.  On my cab, I've noticed some relatively "rough" areas that I actually plan on leaving.  It's giving my cab the old-school 1980's, mass-produced look that I've been looking for.  Of course, I don't plan on leaving drip marks and whatnot on my cab, but I think a few areas where brush-strokes or orange peel are showing isn't the end of the world.   ;D
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
« Reply #8 on: April 18, 2008, 05:31:02 pm »
This is my problem... I wish I had access to one of these things...   :'(
michelevit
« Reply #9 on: April 19, 2008, 08:59:55 pm »
ebay is your friend
so is harborfreight.
i've been through almost a dozen guns
and these is probally one of my favorites...
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46719
and
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92126
this is the best way to paint your project. just thin paint with acetone or laquer thinner
and spray.
