Author Topic: Cutting trackball hole in plastic CP  (Read 2355 times)
billpa
  • Last login:October 01, 2017, 11:25:31 pm
« on: April 11, 2008, 11:00:09 am »
I have a Die Hard cab that is similar to those old Duramold cabs. Its all molded plastic. I wan to cut a hole in the CP for a trackball and I was thinking of using a holesaw since I do not have a router. I know there is a certain kind I should get (in regards to teeth of the bit).
Any ideas?
Thanks,
Bill
Encryptor
  • Trade Count: (+34)
Re: Cutting trackball hole in plastic CP
« Reply #1 on: April 11, 2008, 05:33:56 pm »
I just used a standard bi-metal hole saw with a piece of mdf underneath to support it. Just let the saw do the work and don't put too much pressure on it.
Encryptor
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
« Reply #2 on: April 12, 2008, 11:42:19 am »
There isn't a whole lot of variation among hole saws. Most are bi-metal with a moderately low tooth count. It is possible to find fine-tooth hole saws, though it isn't easy... and may not be appropriate for this application.
If anyone does need a fine-tooth hole saw, you can buy them at  KK Industries. Look for their Rockhard hole saws.
billpa
« Reply #3 on: April 18, 2008, 04:13:34 pm »
Cool...thanks for the tip
