Author Topic: Mamewah Sound problem  (Read 2823 times)
ScooterMAC
  • Last login:April 15, 2012, 12:47:20 am
« on: April 09, 2008, 05:04:02 pm »
I am having some problems with the backround sound in mamewah 1.62. I have put my music in the proper location (C:\juegos\musica and is mapped as such in the cfg file) and it works fine, but if I add more than one nothing plays at all. Also, when the song ends it stops. Is there a certain command I need after the song ({repeat, loop})? I have asked this in another thread, with no luck, but decided to make a new one since somebody else may have this problem. Thanks.
Kick Ass!
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
Re: Mamewah Sound problem
« Reply #1 on: April 09, 2008, 07:30:15 pm »
If you only have one song in the folder it will not loop for some reason.
I whats having the same problem, so I just added a copy of he same song and it worked fine. But that kinda conflicts with your other problem.  Not sure about the multipe songs and not playing.
My suggestion would be to make sure there are no "dead air" in your tracks, possibly shorten down any long file names and make sure mamewah supports the audio file you are trying to play, restart, and hit next track and cross your fingers.
ScooterMAC
« Reply #2 on: April 09, 2008, 08:58:47 pm »
My file name is freedom.mp3 (R.A.T.M.). There is no "dead air" after the song either. Is the problem due to MP3 file, would it work better in a AVI format? What are you guys using? Thanks for the help.
Kick Ass!
« Reply #3 on: April 10, 2008, 04:32:22 am »
I was until recently using MP3's on my cabinet and although I have never had only one song, I know it played all the tunes ok. That said I haven't had music enabled for a while (definately not since I released v1.62final). I will re-enable it and do a few tests to see if I can reproduce this.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: April 10, 2008, 12:15:51 pm »
Just to add to what ScooterMAC said, I only have one mp3 (arcade83.mp3) and when it's done, it's done. I have to restart mamewah completely if I want it to start again. (well, I've never tried the "next track" function)
Also, unrelated to sound, if I run MAME, I can't get NES, SNES, or Genesis (the only other emus I have in mamewah) to work. If I restart Mamewah and go straight to the consoles, they work fine, but if I use MAME, they stop working. This happened in both b13 and the final.
EDIT: Oh, and if I try to launch any emulator other than MAME after MAME has been used, it crashes to windows after a few seconds.
« Last Edit: April 10, 2008, 06:13:57 pm by GinsuVictim »
ideft
« Reply #5 on: April 10, 2008, 06:26:51 pm »
just to add to what ScooterMAC said, I only have one mp3 (arcade83.mp3) and when it's done, it's done. I have to restart mamewah completely if I want it to start again. (well, I've never tried the "next track" function)
it you want it to loop just add another song or a copy of the first ie arcade83A.mp3 and it will loop for you.
As for your other problems sound like Mame is causing some issues.  Check the log for errors .  Can you go in and out of console ok??? can you run Mame more than one time??
Ginsu Victim
« Reply #6 on: April 10, 2008, 08:46:16 pm »
Yeah...I read it the first time. I was just saying that it happened to me too.
MAME runs fine repeatedly. I can play it for hours. It's just when I switch to consoles that it messes up. I can start mamewah and go straight to other emus and they run fine. I can exit SNES and go play Genesis, then jump to NES. The moment I run MAME, I lose the ability to run consoles, but MAME will continue working fine.
« Reply #7 on: April 11, 2008, 09:56:54 am »
What version of Mame? I don't think I have heard of anyone else with this problem...sounds like an odd one  ???
Ginsu Victim
« Reply #8 on: April 11, 2008, 11:23:27 am »
FastMAME .84, the one Gonzo hands out around here like treats on Halloween.
gonzo90017
« Reply #9 on: April 11, 2008, 12:02:31 pm »
 :laugh:
Ginsu Victim
« Reply #10 on: April 11, 2008, 12:04:09 pm »
Thought you'd like that... :cheers:
Ginsu Victim
« Reply #11 on: April 12, 2008, 12:16:08 am »
Minwah:
I tried setting mamewah to run itself on exit (run_app on exit), but it never would work. Since I can't figure out the problem I've having with other emus after running Mame, I thought I'd setup a reset button that would close MameWAH and restart it again. That way the other emus would work.
How exactly should I enter the run_app line? When I just point it to c:\mamewah\mamewah.exe it doesn't work. Is there more needed than that?
ScooterMAC
« Reply #12 on: April 12, 2008, 01:02:23 am »
minwah, can you help me out with my previous sound problem? I'm at my last rope here. :banghead:
Kick Ass!
gonzo90017
« Reply #13 on: April 12, 2008, 01:42:54 am »
GinsuVictim could you post the ini file for Fastmame.
Ginsu Victim
« Reply #14 on: April 12, 2008, 09:58:48 am »
### mame.ini (mamewah v1.62) ###
emulator_title                            Arcade
### List Generation Settings ###
rom_path                                  d:\84-roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\fastmame\fastmame.exe [name]{nodosbox}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       c:\fastmame\snap;c:\fastmame\marquees;c:\fastmame\flyers;c:\fastmame\cpanel
movie_preview_path                        d:\mamevids
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path                                c:\mamewah
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
gonzo90017
« Reply #15 on: April 12, 2008, 11:33:47 am »
That's the same way I have it. ???
You could try changing emulator command line to one of these to see if it exits properly.
Code: [Select]
c:\fastmame\fastmame.exe [name]{nodosbox}{safelaunch}
Code: [Select]
c:\fastmame\fastmame.exe [name]{nodosbox}{nosafelaunch}
Have you checked your mamewah.log  to see what error comes up when you exit mame?
Delete it first so you only get the latest error.
« Last Edit: April 12, 2008, 11:35:21 am by gonzo90017 »
Ginsu Victim
« Reply #16 on: April 13, 2008, 05:29:37 pm »
Ok, figured out what was causing my problem.
The only emulator I was using a gamelaunch.wav with was MAME. None of the others had one.
I deleted that file and everything works fine now.
I don't know WHY it caused an issue, but it did.
So it WAS a mamewah issue, and not emulator based.
« Reply #17 on: April 14, 2008, 05:22:51 am »
Sorry I missed all this but glad you figured it out...thanks for the info. I use a 'gamelaunch' sound but it is global (for all emulators), although I don't see why that would be any different. I'll see if I can reproduce the problem...
Ginsu Victim
« Reply #18 on: April 14, 2008, 08:27:42 am »
Yeah, I might do some testing of my own and send you any errors from the log.
« Reply #19 on: April 15, 2008, 05:18:05 am »
That would helpful, thanks :)
