Author Topic: Construction question  (Read 1134 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: May 27, 2003, 11:31:48 am »
For mobility reasons I need my cab to be disassebleable.  I'm thinking of countersinking carriage bolts through the side panels into an inner frame.  I will then laminate over the sides so the carriage bolts are not visible from the outside.  Is there a way that I can lock those carriage bolts in place (in addition to the square part of the bolt lodging itself into the hole) so they don't spin with the nut when I am tightening/loosening it?  See...once I laminate over the sides I will have no access to the top of the bolt (not that a carriage bolt head would give me anything to hold onto anyway).
I've attached a picture to better show my idea.
« Last Edit: May 27, 2003, 11:32:52 am by shmokes »
Best Kid iPad Apps
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
Re:Construction question
« Reply #1 on: May 27, 2003, 11:52:00 am »
In a word, no not really. Once the nut starts to tighten up on the bolt, and the little square nub underneath the top of the bolt starts to dig in, that ought to give you all the torque you need.
Tighten it up and you're done.
If you need to, buy bolts that are long enough for you to get a pair of vice-grips on the end of em, but you'll risk destroying your threads.
IMHO Dont sweat it, once the square-part bites into your hole (assujming you didn't drill too wide of a pilot hole) you'll be fine.
".....its like a Koala crapped a rainbow in my brain!"
OSCAR
    • Oscar Controls
« Reply #2 on: May 27, 2003, 12:48:51 pm »
Instead of having the bolt heads under the laminate, why couldn't you countersink in T-nuts; you shouldn't need access to those after they are installed.  Then run the bolts in from the inside.  Just be really sure your bolts aren't too long and poke into the laminate.
locash
  • Last login:March 22, 2008, 06:45:21 pm
  • Got cash?
« Reply #3 on: May 27, 2003, 02:57:08 pm »
I would recommend using cross dowel connectors whenever making knock-down cabinets out of MDF.
http://www.leevalley.com/hardware/page.asp?page=44238&category=3,43715,45375&ccurrency=2&SID=
"I believe that every individual is naturally entitled to do as he pleases with himself and the fruits of his labor, so far as it in no way interferes with any other men's rights."
Abraham Lincoln
