Author Topic: Golden Tee Mame project  (Read 2693 times)
wrighty
  • Last login:May 22, 2008, 06:48:32 pm
« on: April 08, 2008, 08:36:09 am »
Hey all this is my first post so please be gentle!!
I am wondering how can I make a control panel (2 joystick, 6 buttons each side) as the golden tee machine just has a track ball? And how does my arcade monitor conect to the PC? The machine is JAMMA and fully working as I have put my old SF2 board in for testing. I cant get my head round what I need to do and I am also very cautious of playing in the back of the cab due to the high voltages etc! My job is in IT so even though the above sounds a bit vague im sure someone can help me!
Cheers!!
wrighty
Re: Golden Tee Mame project
« Reply #1 on: April 09, 2008, 04:12:42 am »
Can anyone help please?
NoOne=NBA=
« Reply #2 on: April 09, 2008, 09:33:59 am »
You should be able to replace just the top piece of wood on the control panel, if you want to.
Just copy the piece that's there exactly.
If that's too much work, you could plug the existing holes, and redrill your own.
As for hooking up the computer, the best way is a JPac and an ArcadeVGA.
The JPac handles all the inputs, and the ArcadeVGA handles the video.
There are other solutions, but that one is easy, and out of the box.
Both pieces are available at Ultimarc.com
wrighty
« Reply #3 on: April 09, 2008, 01:25:52 pm »
Cheers for that!! Has anyone got any knowledge of the Golden tee architecture? Looking at it all I have is the Jamma connector and some wites that were connected to the trackball. Where do I wire the buttons/joysticks to as the golden tee machine only has a trackball and 2 buttons? Also what gauge wire etc will I need?
wrighty
« Reply #4 on: April 10, 2008, 12:28:46 pm »
From what I understand the JPAC acts as an interface between the jamma and the PC, am I correct with this?
Below is a link of the Golden Tee Jamma pinouts
http://www.jammaboards.com/pinouts/Golden%20Tee.txt
Obviously, The joysticks are not wired in nor are the buttons.
How do I get the wires from the Jamma connector to my controls, do I need special connectors or do I need to solder or something?
phishpac
  • Last login:October 15, 2009, 10:42:19 am
    • grateful arcade
« Reply #5 on: April 10, 2008, 12:39:30 pm »
Some searching on the forum will provide you all the answers you are looking for in your project.  Take the time to use the search feature and you will find many threads of people doing similar builds.
You can use any type of connection you want with your wires.  You can use quick disconnects (the most popular, they are the male and female contacts the join together), crimp on connectors, and if you really wanted to you can solder the connections.
Your basic jamma pinout is here:
http://wiki.arcadecontrols.com/w/images/9/93/Jamma-pinout.gif
This will help you in your wiring of the controls.
I would suggest visiting the BYOAC wiki at:
http://wiki.arcadecontrols.com/wiki/Main_Page
It is an easy to navigate source of information that will help you greatly in your build.
good luck and keep us updated
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #6 on: April 10, 2008, 12:41:07 pm »
Forget the J-Pac your cabinet isn't wired for sticks and buttons and given the number of wires you'd have to run to the J-Pac it's not worth using a J-Pac and the existing wiring. Mostly because the Golden-Tee machine does not have a complete JAMMA loom.
Fit the PC with the Arcade VGA card to give you video that will drive the arcade monitor and either get an I-Pac and wire your controls to that, or get a Keywiz http://www.groovygamegear.com and wire them to that.
Many of the basic questions you are asking here are also answered in the http://wiki.arcadecontrols.com/ read read read!!!
Also!! Buy Saint's book!! you'll find it on Amazon....   http://www.amazon.co.uk/Project-Arcade-Machine-Digital-Lifestyle/dp/0764556169/ref=sr_1_2?ie=UTF8&s=books&qid=1207845584&sr=8-2 It's invaluable to all Arcade noobs!! lots of good advice... buy it and read it cover to cover.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
wrighty
« Reply #7 on: April 10, 2008, 02:52:29 pm »
Cheers for that! Sorry for all the newbie posts! Its just I have had the machine in my garage for months and have a week to at least start! Ill keep you posted!!
wrighty
« Reply #8 on: April 11, 2008, 10:44:11 am »
Book has been ordered and after a few posts in other areas I have my plans!! Just one quick last noob question! In my golden tee machine I have 2 speakers in the front (which off the top of my head are connected to my Jamma loom). Can I use the speakers for my project or will I need some PC speakers to take the sound? It would be nice to have the Cabinet speakers for authenticity though! Im guessing the only way I could do it would be by hacking a PC amp somehow?
Cheers again!
phishpac
    • grateful arcade
« Reply #9 on: April 12, 2008, 02:42:35 pm »
the book has a whole write up about hacking a pc speaker amp.  wiki has info too
