Author Topic: tms320dm642 Evaluation Module  (Read 1456 times)
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« on: April 07, 2008, 12:41:49 am »
I came across one of these.
http://www.spectrumdigital.com/product_info.php?cPath=37&products_id=121
As far as I can tell it's some fancy video card.
Anyone know what it can be used for?
MonMotha
Re: tms320dm642 Evaluation Module
« Reply #1 on: April 07, 2008, 02:00:39 am »
What you have is a fancy development board for a DSP chip from Texas Instruments.  The DSP is design for video processing work (compressing/decompressing, scaling, etc.)  This board is designed for developing products based on the chip and algorithms to run on it.
Unless you're into designing video hardware and software, it's not likely to be particularly useful.  I'm moderatly interested, though.
Bleagh
    • BLEAGH!
« Reply #2 on: April 07, 2008, 08:07:44 pm »
I dont suppose I could use it as a video card and take advantage of the many inputs and outputs then?
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #3 on: April 07, 2008, 10:15:03 pm »
Sure you can.  You just need to write some drivers.
MonMotha
« Reply #4 on: April 08, 2008, 03:19:34 am »
And likely some firmware to run on the DSP, though there may be enough evaluation stuff to get some semblance of video output working if you have all the software that came with the EV kit, as well as the board.
