Author Topic: Where do people get this thing?!  (Read 1789 times)
LoyalistRevolt
  • Last login:June 19, 2008, 08:52:07 am
  • SEGA!
« on: April 06, 2008, 01:32:45 am »
not the joystick of course but the rubber looking thing I really need some!
Not posting doesn't make you a noob, ignorance, stupidity, laziness, and talking trash make you a noob.
Just cause I don't post in threads doesn't mean I don't read the threads...
  • Last login:December 16, 2025, 04:07:15 pm
Re: Where do people get this thing?!
« Reply #1 on: April 06, 2008, 01:37:05 am »
I've had good luck at gas stations
LoyalistRevolt
  • SEGA!
« Reply #2 on: April 06, 2008, 01:38:49 am »
I don't know how to react to that one....
SirPeale
  • Green Mountain Man
« Reply #3 on: April 06, 2008, 03:22:47 am »
They come with joysticks.  That's the only place I know to get one.
vorghagen
  • Last login:September 05, 2017, 01:06:59 am
« Reply #4 on: April 06, 2008, 05:43:33 am »
I'm assuming you want one for a more responsive stick. ie less movement required to activate microswitch.
If that's the case and you can't find the rubber thing, take the low tech route: wrap the bottom of the shaft with electrical tape until it reaches desired responsiveness, or stick a chunk of blue tack there.
Never argue with an idiot, he'll just drag you down to his level and beat you with experience.
Encryptor
  • Trade Count: (+34)
« Reply #5 on: April 06, 2008, 08:42:12 am »
Check on Ebay. There are people selling joysticks and pieces parts all the time.
Encryptor
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #6 on: April 06, 2008, 09:20:48 am »
Is that a Happ Competition stick ?
I've ordered individual replacement parts (springs, actuators) for Happ sticks in the past -- unfortunately I can't reach happcontrols.com to check.
Working: Not Enough
Projects: Too Many
Progress: None
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #7 on: April 06, 2008, 09:58:34 am »
Yeah, I did that with mine, although I had to go back and do it every so often, as the tape would slowly work its way off the actuator. I've since bought a pair of used leaf switch joysticks, but they're a little shorter, and I'm not 100% satisfied with them yet either.
LoyalistRevolt
  • SEGA!
« Reply #8 on: April 06, 2008, 11:30:33 am »
Man I never got one with mine
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« Reply #9 on: April 06, 2008, 12:35:21 pm »
I have two of those on some die hard arcade sticks in my garage, I will pm you when I find them, im about 80% sure I kept the old sticks, you can just pay postage and I can mail them to you, I have no use for them.
LoyalistRevolt
  • SEGA!
« Reply #10 on: April 06, 2008, 02:59:00 pm »
THANKS MAN! :cheers:
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
« Reply #11 on: April 06, 2008, 04:32:11 pm »
If he can't find those... Lizardlick sells those.  They're called the actuator
http://www.lizardlickamusements.com/pages/joysticks.shtml
