Author Topic: Proper Hole Width on CP for Competition Joysticks?  (Read 2308 times)
crackbone
  • Last login:April 30, 2010, 02:50:05 pm
« on: May 26, 2003, 07:02:21 pm »
Hi all!
I'm at the finish line for my cabinet (thank god!!!!) and I'm drilling the CP now.
My question is this-
I have a 3/4 " CP, with a 1/8" Lexan overlay, with happs competition joysticks to put in.   When I'm drilling the holes, what width should I make the holes for the joysticks?
I know people have mentioned that the range of motion might be limited if I don't route the bottom out, so if that's the case can I make a wider hole to accomadate this?
Thanks for any advice... I'd like to only drill this once :)
Crack.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Proper Hole Width on CP for Competition Joysticks?
« Reply #1 on: May 26, 2003, 07:05:43 pm »
Typically people make a 1 1/4" dia hole and route out a 1/4" of the control panel thickness.
If you build a frankenpanel, chances are I don't care for you as a person.
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« Reply #2 on: May 26, 2003, 07:15:29 pm »
Well, i'll tell you my experience.
I have a 3/4 " plywood top panel and i routed out a 2/8" amount of wood from the underside of the panel to allow for my joysticks to be up high enough.
I ended up useing a black and decker rotary saw which i could set how deep it would cut and it worked great!
Ild say if you haven't  put your panel together yet (ie: the sides and bottom) then use a router to cut your depth.   it seems like you will need to cut out about 3/8'ths deep to get a good joystick throw.
i also ended up useing an 1 3/4 inch  hole saw for the hole for the joystick.  It worked great!
Might want to get a second oppinion on how deep to recess the routing to allow for the lexan as i didnt use any lexan.  I found some good enamel paint works just as good.  :) Lesscutting too hehehe.
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: May 26, 2003, 07:15:37 pm »
*cough* I don't have competitions (I have super clones)... but i used 1 1/8" hole saw (same as my buttons) for my joysticks... on 3/4" plywood (no lexan on top)...
*shrug*  I don't think you could go wrong with either 1 1/4" or 1 1/8" for joystick holes... just being contentious.
rampy
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: May 27, 2003, 04:37:01 am »
Both my supers and (hacked) competitions have 1 1/8" holes, but 1 1/4" will work too.  Routered about 1/4" to 3/8" on the bottom, and am very pleased with the results, but some people complain that 3/8" isn't enough. *shrug*
Robin
Knowledge is Power
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
« Reply #5 on: May 27, 2003, 05:45:50 am »
what is a "hacked" competition?
Yes competitions have a designed mounting depth in 1/2" wood so 3/4" needs routing to clear it out for the "proper" stick height. I find that Ultimates fit fine in 3/4 but many people here hate them.
1.125" needs to be dead center if you want 3/4" + an acrylic overlay. If it's not lined up in the dead center then you'll wear a ring in your handle cause it'll hit.
skirge66
  • Last login:June 03, 2003, 06:25:58 am
  • the stupid will normally punish themselves
« Reply #6 on: May 27, 2003, 06:54:08 am »
I mounted my competitions in 3/4" mdf...like stated over and over above, I routered them in 1/4" and used 1 1/8" hole same as my buttons, plenty of room and no problems
skirge66
Diplomacy is the art of saying "nice doggy" until you find a bigger rock to throw
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
« Reply #7 on: May 27, 2003, 11:35:08 am »
I'm using 1/2' MDF with 1/8" lexan over it. Can a paddle bit be used rather than a hole saw?
rampy
  • *shrug*
« Reply #8 on: May 27, 2003, 02:58:25 pm »
yup if paddle== spade bit in my terminology.
you can also use a forstners bit (but better off with a drill press/guide)
*shrug*
rampy
steve_pss
« Reply #9 on: May 27, 2003, 04:17:09 pm »
wish i had a drill press, dont and i need to go through 1/8 lexan and the 1/2 inch MDF. hoping to clamp the 2 pieces together and drill in one shot.
rampy
  • *shrug*
« Reply #10 on: May 27, 2003, 04:38:22 pm »
It's not required (except it's a good idea with a forstners bit, from what I understand)... and is helpful with other bits obviously...  but plenty of people have done just fine with spade/paddle/hole saw bits without a drill press, including me...
Just wanted to give you more information than you needed, i think=P
rampy
steve_pss
« Reply #11 on: May 27, 2003, 04:42:58 pm »
mucho helpful, but yet one more trip to the Home Despot shall be required. My Wife, is going to kill me.
armad1ll0
    • Modeverything
« Reply #12 on: May 27, 2003, 05:38:24 pm »
drill press isn't the best for this because of the fact that your control panel might just be too wide. There another tool which fits on a hand drill that guilds the bit down for a perpendicular hole. I forgot what it's called. but it goes on your hand drill. I basicall put my control panel on the ground and drill down using my weight to hold the acrylic onto the MDF
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #13 on: May 27, 2003, 09:12:09 pm »
Robin
Knowledge is Power
