Author Topic: Can I make Direct-X use 640x432 when I select 640x480?  (Read 1409 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: April 02, 2008, 07:52:13 pm »
A lot of the games I play only support specific resolutions such as 640x480 and 800x600.
However, when I use component video I'm _required_ to use 640x432 or else there is HUGE overscan.
Can I somehow (eg. powerstrip?) fake Direct-X into using 640x432 even when I select 640x480?
...or are there other fixes to this?
Ginsu Victim
  • Comanche, OK -- USA
Re: Can I make Direct-X use 640x432 when I select 640x480?
« Reply #1 on: April 03, 2008, 11:12:30 am »
Can you do a software resize of the image output? Most video card utilities have some sort of option for this.
sofakng
« Reply #2 on: April 03, 2008, 11:29:12 am »
For some insane reason, the latest ATI Drivers only let you re-size the screen if you use S-Video or component output of 720p or higher.
I'm using 480i output and I can't re-size the screen what-so-ever. :(
Ginsu Victim
« Reply #3 on: April 03, 2008, 11:37:34 am »
Powerstrip MIGHT let you change screen size (I'm not sure, I've only used it to force 640x480 on my Voodooł).
