Author Topic: discolored monitor help  (Read 2187 times)
CartmanDP1
  • Last login:October 08, 2008, 05:22:34 pm
« on: April 02, 2008, 05:05:52 pm »
i have a crt monitor and the neckboard fell off in transport, i put it back on but now the edges of the screen are all purple/green. Is there an easy way to fix this? I tried to degauss,  when I do the screen looks perfect for a split second and then reverts back. Will this work?
http://www.metacafe.com/watch/387073/repair_magnet_damage_on_your_monitor_or_tv_in_5_seconds/
« Last Edit: April 02, 2008, 05:07:50 pm by CartmanDP1 »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: discolored monitor help
« Reply #1 on: April 02, 2008, 11:13:45 pm »
first, use a manual deguassing coil.     or the magnet "trick" if thats all u got...
it shouldn't "look perfect for a second then revert"  .
disconnect the internal coil , then deguass.
if pic stays normal, the thermistor could be defective or just loose.
qrz
FrizzleFried
    • Idaho Garagecade
« Reply #2 on: April 03, 2008, 08:35:11 am »
I have a monitor that won't degauss completely too.  I have a manual degauss coil and the top of the screen's RED won't come in completely...it has a yellowish tint.  I've tried everything.  The only thing that works is facing the game a different direction,  which isn't something I can really do as it's where it will fit.
grantspain
« Reply #3 on: April 03, 2008, 01:42:15 pm »
frizzlefried maybe one of the monitor fixing bolts is magnetized or a speaker a wee bit close
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: April 03, 2008, 02:49:05 pm »
If the problem was consistent regardless of position I'd think so...but if I face the cab the opposite direction it's fine.
It's an "Earths Poles" thing.
whammoed
  • Last login:Yesterday at 10:01:01 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #5 on: April 03, 2008, 04:04:37 pm »
I have found it hard to get the color correct in one corner of my cockail where it was at the old house.  It is much better where it is situated in the new house.  Manual degausing wouldn't even cut it.  I definitely think its possible to have a monitor that just won't be happy in a particular spot.  I do think you can tweek things by placing small magnet(s) around the perimeter of the monitor where they would help.  Then again, I could be full of ---steaming pile of meadow muffin---.
qrz
« Reply #6 on: April 04, 2008, 07:05:24 pm »
have had to resort to magnets on occasion.
don't place them on the crt coating. find a clear spot towards yoke or on edge .
if improperly placed , the internal deguassing coil may nullify the correction.
qrz
