Author Topic: Tube Compatibility  (Read 1837 times)
FrizzleFried
    • Idaho Garagecade
Tube Compatibility
« on: April 02, 2008, 04:52:36 pm »
I have a real nice looking tube that came with a funky Sharp Image chassis that is dead and sparking. I'd rather just drop a known working chassis in, but I am not 100% sure of the compatibility of the tube. The frame is a Wells Gardner frame (at least it has WG labels) but the tube is not original. The chassis LOOKS like a WG chassis but is a SI.
The tube numbers are G-A48AC802X and O4RC0872-005.
The vertical resistance is 2.4 ohms
The horizontal resistance is 11.7 ohms
It has a 10-pin neck.
Will a WG K7000 chassis w/10-pin neck work with this tube?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Tube Compatibility
« Reply #1 on: April 02, 2008, 11:22:12 pm »
a48acb02x is standard notation . the  "O4RC0872-005" sounds like  "house numbering " from a mfg.
as long as the pin outs are the same , it should be usable . reuse the original yoke so no need to worry 'bout deflection compatability issues .  mark the position of the convergence rings on the donor tube . do not disturb the ring position when removing . reinstall ring in same position after installing yoke .
if the chassis was ok , a few adjustments and it should be up and running ....
qrz
