Author Topic: Quick MAME question here....  (Read 1388 times)
newkillergenius
  • Last login:September 21, 2013, 03:48:35 pm
  • A mind is a terrible thing to taste.
    • The Mystery Revealed!
« on: April 01, 2008, 09:20:49 am »
Gents,
I've got an extra 700MHz P3 board with 700-something MB of RAM, 30GB HD.
Im thinking of doing just a classic MAME cab- which version of MAME would you suggest?
I tried running the MAME101 (the one with the frontend)  but it lags the sound!  Even on ollld stuff
like Karnov & Robotron?  Any suggestions?  Just want it to run about 50-60 classics, not a powerhouse or anything.
Whats the best version for this?  Also, want to omit the mouse, but with this small amount of balls, FE's like
Atomic probably wont cut the mustard.  I assume, Im not sure.  Any feedback is APPRECIATED, cheers guys!
Don't ---steaming pile of meadow muffin--- where you eat, my friend.
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
Re: Quick MAME question here....
« Reply #1 on: April 01, 2008, 11:06:32 am »
Try spystyles boot cd(or fraggal's - if you can find it).  It's a fairly easy way to do a classics MAME cabinet  I'd start working my way back through the 7 included versions until the sound no longer lags, or start with 0.36.  and work my way up from there.
  • Last login:December 02, 2025, 03:23:14 pm
« Reply #2 on: April 01, 2008, 11:06:45 am »
Definately use an older version of MAME...  maybe in the .7 range?  I have a version at home that runs on older PC's, I'll have to look at it to figure out which it is.
You could use Game Launcher as a FE.  I've used it on a slower PC than yours with good results.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #3 on: April 01, 2008, 11:11:56 am »
Atomic can perfectly fit your machine. You Just have to choose a appropriate layout.  (for instance in the layout folder there is a layout for slow machine, it should fit)
I use it perfectly  on a Celeron 500Mhz with 256Mega of Ram.
I can help you to do your set up.  If you take a very old version of mame there is special settings to do.
gonzo90017
« Reply #4 on: April 01, 2008, 11:52:58 am »
Try using FastMame 84. If you still have problems, which you should try using Fastmame071b. AtomicFE should run fine on that setup. I think you just pass Mala's system requirements. Mamewah should run on anything i'm using it on a 400mhz celeron with 256mb and it runs flawlessy, even using video previews.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #5 on: April 01, 2008, 05:14:24 pm »
^This. I'm using a 733 Mhz and FastMAME84 (plus MameWAH) has been great.
