Author Topic: Discharging my D9200  (Read 1493 times)
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« on: March 28, 2008, 10:26:47 pm »
This is only the second time I have done it, but both times I have never heard any noises nor flashes.  The monitor was just on an hour before too..
Kinda wish it made noise to know that it's doing something.
Now with cup beer holders!
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
Re: Discharging my D9200
« Reply #1 on: March 29, 2008, 12:46:56 am »
Sometimes it is like that.  Depends on the monitor.  Some of these other guys could give more specifics of why that is.  Just make sure you always do it...... cuz the one time you don't.   :dizzy:
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: March 29, 2008, 10:42:17 am »
some circuits have a bleeder resistor that will "bleed" off the hv. this type usually "crackles" upon deactivation
 :soapbox:    DO NOT rely on this .
 to eliminate the possibility of a unpleasant surprise , always manually discharge before handling crt.
qrz
DeathMonk
    • MameStation.3
« Reply #3 on: March 29, 2008, 11:05:11 am »
Oh, I did!  ;D
Read it with a volt meter after I did it a couple times, too.  A big "0"
Kevin Mullins
    • Me on Myspace
« Reply #4 on: March 29, 2008, 01:49:36 pm »
Read what with a voltmeter ??
Unless you have a high voltage probe and your meter is capable of reading high voltages I don't recommend doing that ...... unless you don't mind replacing your meter.
Many newer monitor have the bleed off circuit as mentioned already. If it doesn't snap or pop when you discharge then it should be fine. The only thing I would suggest is discharging the anode hole on the tube itself one more time before putting the anode lead back in just to make sure the tube itself didn't build some static charge while sitting with the anode lead off.
And remember..... it's the TUBE that'll get ya, not the anode wire itself.
Seems that everyone fears the big red wire. But it's the tube that is holding the charge.
