Author Topic: MaLa "always playing" LedWiz animation??  (Read 2537 times)
robC
  • Last login:December 13, 2017, 11:59:59 am
« on: March 26, 2008, 08:57:01 am »
I don't know if this is possible or not. I currently have MaLa set up with the LedWiz plugin, and I am just setting a default color set for my control panel that stays on all the time in MaLa. This works great. But is there also a way to have a single animation that plays constantly while I am in MaLa? I would like to have a simple color cycling animation that is always going rather than the static color set.
Rob
loadman
  • Moderator
    • MaLa
Re: MaLa "always playing" LedWiz animation??
« Reply #1 on: March 27, 2008, 05:14:41 am »
So while in th emu you want animation the buttons set when the game is playing right?
I think I made a custom version of the MaLa ledwiz plug-in like this for another user mid last year?
robC
« Reply #2 on: March 27, 2008, 08:05:15 am »
Yep, thats the idea. I just want to set up a simple animation to loop continuously all the time. Thanks for any info you can provide!
-Rob
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: March 27, 2008, 08:49:18 am »
If Loadman can't hook you up with a custom version – another option would be LEDBlinky – it can play an animation while the FE is active.
Robots will kill you.
Arcade Addiction
