Author Topic: mamewah and defult rom listing  (Read 4612 times)
jardine
  • Last login:May 12, 2025, 05:09:12 am
« on: March 25, 2008, 04:44:32 am »
Hey...got mamewah and found when i generated a list of games it generated over 700+ of them. I don' have anywhere near this amount...how can i remove the ones showing that i don't actually have. I know i can do it individually but is there an easier way.
Also...rather than having the listing as wboy2 for example can i customise this to show WonderBoy.....
I have a few other questions but i bother everyone later with these...
Thank u guys/gals
gonzo90017
Re: mamewah and defult rom listing
« Reply #1 on: March 25, 2008, 02:07:36 pm »
You didn't mention which emulator you were using. But since you mentioned wboy2 i'm assuming you're using mame. The easiest way to generate a list that shows the rom name is by figuring what mame version you're using then downloading the dat file (cm) from here. Then you open you're mame.ini in mamewah's config folder. Then you modify a couple of lines:
Code: [Select]
dat_file                                  C:\juegos\mame37\MAME v0.37b16.datOf course you modify it to point to your own dat file.
Code: [Select]
list_generation_method                    rom_folder_vs_dat_file
jardine
« Reply #2 on: March 25, 2008, 07:34:43 pm »
Just want to clarify gonzo... i wish to change the listing of a particular game in mamewah to show it's full name. So instead of the listing showing the rom name ie:wboy2 i want it to show WonderBoy 2.
Will what you said change this to show the listing to be WonderBoy 2? And yes, sorry it's mame .123
Hope im making sense...just woke up.
gonzo90017
« Reply #3 on: March 25, 2008, 07:41:04 pm »
Yes. Using a dat file will show the full name.
jardine
« Reply #4 on: March 25, 2008, 07:45:17 pm »
Thanx...worked beautifully.....much appreciated    :applaud:
« Last Edit: March 26, 2008, 12:48:54 am by jardine »
« Reply #5 on: March 26, 2008, 11:32:41 am »
This will work and there is nothing wrong with doing this, but for the benefit of anyone who reads this, I do not agree this is the 'easiest' way! It depends on what version of Mame you are running but for Mame v0.123 you should set:
list_generation_method rom_folder_vs_listxml
(Note: Mame versions prior to v0.84 should use rom_folder_vs_listinfo)
I say this is easier because you don't need to download a dat file, and you don't need to do anything if you replace your mame.exe with a newer version - just refresh the list.
Hypaspazz
  • Last login:December 16, 2017, 10:01:55 pm
« Reply #6 on: April 02, 2008, 11:53:58 pm »
I can't get the XML method to work.  I can only get the dat_file method or direct list method to work.  Is there something that I need to do under mame to get the XML method to work?  Thanks.
jardine
« Reply #7 on: April 03, 2008, 05:46:00 pm »
Do you mean that you get no list gen method at all?? If so, i needed to download the xml2 file from the mamewah website to generate a list first....see if that helps.
http://mamewah.mameworld.net/downloads.htm
Hypaspazz
« Reply #8 on: April 04, 2008, 03:20:01 pm »
Got it to work.  Thanks.
emopants92
  • Last login:July 18, 2010, 02:36:30 pm
  • I am Sparkles, And I am obber SCARY!
« Reply #9 on: August 11, 2008, 09:04:59 pm »
Anyone know where to get the xml file at? because its not avaliable on the mamewah downloads page?
Some times every one needs a good scare, Take (S)'Care
jardine
« Reply #10 on: August 11, 2008, 09:41:51 pm »
The dat link is still up..use that till you find it. Minwah may have pulled it from his website as it was for v1.62 from memory...v1.63 is what he probably supports..will see if i can post it here for you later today. At work so will have to check back later today/tonight
