Author Topic: Analog Stick guns?  (Read 3043 times)
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
Analog Stick guns?
« on: March 24, 2008, 08:20:53 pm »
  Hello,
 I have Been Really getting into the Light gun idea.
Been Reading up.. Already own LCD Guns and Act Labs.
 They both have their advantages but neither seems
 quite right for a Mame Cabinet.
They seem more like the guns to use while kicked back
on the couch!
 What I'm thinking Is this:
Has Anyone Designed a Mame guns that simply sits on
top of a Joystick like Terminator 2 did?
If Hasn't already been  designed .... Why Not?
While I have not put together a Mame Cabinet yet..
( guns I have work fine for now)
To me at least these type of stationary guns would
be Ideal for a Mame Cabinet.
So what do you think?
padstack
  • Last login:February 03, 2024, 12:54:24 pm
Re: Analog Stick guns?
« Reply #1 on: March 24, 2008, 08:24:39 pm »
You might want to grab that flame-retardant suit...  And check the search while you're at it...
Time for the forum wrath to rain down!
Games001
  • Last login:January 13, 2024, 12:44:04 am
« Reply #2 on: March 24, 2008, 08:26:48 pm »
No Forum wrath... just Fozzy's  :laugh2:
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #3 on: March 24, 2008, 08:46:16 pm »
Well, to be practical, they would get in the way of the other controls (assuming this was for a MAME cab, not a dedicated-stationary-shooter cab)
</flameless reply>
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #4 on: March 24, 2008, 08:52:42 pm »
 noob :tool:..... You pissed more people than me off with your repeated posting of multiple threads with the same damned question in them.
Regards,
Julian (Fozzy The Bear)
« Last Edit: March 24, 2008, 09:00:06 pm by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Fozzy The Bear
« Reply #5 on: March 24, 2008, 08:59:27 pm »
It'd be an easy one to do if you really wanted to.... However, TelcoLou hit the nail on the head. Unless you're building a dedicated static shooter cab or fitting swappable panels, then they'd get in the way of everything else.
The thing is that that they don't just sit on top of a Joystick.... they do have an up/down (back to forward) movement like a joystick, but the other axis is not side to side like a joystick, but a rotary twist for the left to right of the gun.
In actual fact Act Labs released a gun that was just a thing, siting on top of a joystick.... it was a miserable failure and very very difficult to play anything with. I think it was called something like "The Mousegun" or something similar... anyway, to cut a long story short, it was crap!
The other problem with pot based guns like the T2 ones, is that they only work well with pot based shooter games. On top of that, there are still problems with the interpretation and use of POT based inputs in Mame.  Jurassic Park is a case in point, where guns track very badly even after calibration.
If you really want some of those, then pick up a set of T2 Guns off e-bay (they sell for next to nothing most of the time) and you can very easily interface them to a PC and Mame.
Best Regards,
« Last Edit: March 24, 2008, 09:10:04 pm by Fozzy The Bear »
TeutonicDarkness
« Reply #6 on: March 24, 2008, 10:19:57 pm »
 What is that suppose to mean...?
Yes I have Searched very extensively at least
the last 3 years.
Which is the exact reason I made this post.
TeutonicDarkness
« Reply #7 on: March 24, 2008, 10:55:40 pm »
 You are probably right it just seems there would be a way if it
was used on a wide enough control panel and placed cleverly enough.
Though I admit I have no experience designing control panels..
 Yes I am aware of that I should have been more technical in my
first post.
But Maybe a mechanism of some kind that could rotate
as a gun would need to. Wither  it be a sit on top solution
or independent it could send key signals to Mame as a regular
Mame joystick would.
 Yeah everything I ever heard about the mouse guns was Bad..
My point is I can control all those game like Terminator, Area 51,
etc.. right now with just a joystick and it works.
Just if it had a more of a way to aim like simply holding a
gun in your hand.
 Well I know what your saying which is my I was thinking/wondering
of a Mame-Joystick route.
Best Regards,
 That is a interesting thought though probably not
a permanent solution. I would not begin to know how to interface
them; Would seem like a waste just for a handful of games as
much as I loved Terminator.
 Maybe it just not a do-able solution don't know
just seems it would defiantly be more compatible.
At any rate...
thanks for your input!
Teutonic Darkness
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: March 25, 2008, 02:40:58 pm »
IIRC, someone here had a removable pair of joystick guns on his cab, but I can't fine it ATM.
They should work as well as lightguns on lightgun games.  At least, the u360 in analog mode works well on the lightgun games I've played.  Why do you say they'll only work well with POT games?
I agree calibration will be the problem.  Depending on the POTs used and the windows driver and driver settings, and mame settings, and the original game coding the mame's emulation code, ;D a joystick gun might track well in the center but not the edges or vice versa, or good in X axis but not Y or vice versa.  Then again it might be on site on the whole screen.
I haven't tried jurassic park, though.
Robin
Knowledge is Power
Fozzy The Bear
« Reply #9 on: March 25, 2008, 03:08:28 pm »
They should! being the pertinent phrase there..... My experience is that a set of T2 guns tracked very badly in the tests I did with them on nearly everything except the pot based shooters.
Do try it, it's at least good for a laugh..... The problems may have been fixed in the more recent versions of Mame, haven't tried it in the last year. But the last time I looked at it the guns would track OK for half of the screen, then refuse to track at all past that point.
Best Regards,
Bluedeath
  • Last login:June 19, 2014, 11:20:09 am
« Reply #10 on: March 26, 2008, 04:32:48 am »
T2 is playable either with with LCD tTOP GUN or an analog stick (cheap usb one will do) but the gameplay will sucks, i tried to scratch build positional guns with poor results. To achieve good result the position of the gun base and the screen must never change if you try to use positional guns on a PC remember that arcade joystick pots are usually 5k and PC pots are 100k (custom 10~30° of travel) or 500k used only from 0 to 100k, this trick is used in the cheap sticks and by saitek, but saitek sticks do have a dedicated circuitry that optimizes the signal and give same results of custom pots.
Actually i'm looking for a set of T2 guns (op thunderbolt, rev x etc are all the same any of them wil do) to hack if the price is near nothing (and they are already in europe)  please let me know.
« Last Edit: March 26, 2008, 11:41:17 am by Bluedeath »
I give up  fighting keyboard dislexia, I lost.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: March 26, 2008, 02:18:57 pm »
...To achieve good result the position of the gun base and the screen must never change...
That's a given. :)
...remember that arcade joystick pots are usually 5k and PC pots are 100k (custom 10~30° of travel) or 500k used only from 0 to 100k...
You do need to worry about this if you're hacking gamepads or connecting through the gameport.
But just get any modern interface that can do 5k to 100k POTs.  A-pac2 does any POT that outputs 0 - 5v automatically; many flightsim interfaces do this too (I've tested the plasma).  Even the old A-pac1 and AKI can do 5k and 100k POTs.
Robin
Knowledge is Power
TeutonicDarkness
« Reply #12 on: March 26, 2008, 08:37:35 pm »
 Exactly ... I just don't see how this I possible using
Act Lab guns, or EMS top guns.
There has to be a solution to having a Mame Cabinet
and fixed guns?
Or is there?  ???
***Teutonic Darkness ***
Bluedeath
« Reply #13 on: March 27, 2008, 04:14:52 am »
with the lcd (taking for granted that you calibrated the gun and the game in a mamanner that position coordinates of the game and aof the gun are the same) you can ingnore this statement because for the top gun it matters where is pointed not the postition, the game play will not be the same that you may have with a positonal gun.
« Last Edit: March 27, 2008, 05:02:03 am by Bluedeath »
« Reply #14 on: March 27, 2008, 06:47:09 am »
I think screen size, control panel angle & distance from monitor etc are other factors which mean a commercial positional gun will probably never happen.
