Author Topic: what is a good thin wood?  (Read 2639 times)
noobofthecentury
  • Last login:April 15, 2008, 01:18:00 am
« on: March 24, 2008, 04:40:47 pm »
What type of wood meets these conditions
- thin (1/4 inch)
- if cut 7 inch by 11 will still hold pretty strong
- can be drill with hole saw
  • Last login:Today at 04:55:22 pm
Re: what is a good thin wood?
« Reply #1 on: March 24, 2008, 04:41:25 pm »
Kinda depends on what you will be using it for?
noobofthecentury
« Reply #2 on: March 24, 2008, 04:50:06 pm »
I am using it for a external control panel
Kinda like a mini control panel for arcade but I can use it on my console too.
I build the 4 sides made of 1/2 inch MDF glued together
I am looking for a thin wood to be the top panel (where I will make holes for button)
I will also add 1/8 plexiglass on top of this top layer.
I want to avoid using router but get the maximum joystick height.
is this a good wood?
Baltic Birch Plywood, 6mm - 1/4" x 12" x 12"
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
« Reply #3 on: March 24, 2008, 07:26:54 pm »
Given your application, you almost have to use plywood. Baltic Birch is an excellent choice. 1/4" is pretty darn thin, though. If you're planning to pound on your buttons, you'll probably want at least 1/2"...
Jdurg
« Reply #4 on: March 25, 2008, 10:53:26 am »
Also, keep in mind that the thinner the plywood, the more likely it is to be severely warped.  So be prepared to take some time and "flatten" it out.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
shardian
« Reply #5 on: March 25, 2008, 11:27:13 am »
Luan plywood would work in that small of dimensions. For my single player desktop CP, I had some scrap sheets of 1/4" hardboard. It is super sturdy on that small of a scale.
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
« Reply #6 on: March 27, 2008, 06:21:03 pm »
luan has a tendency to bleed thru. if you're putting an overlay on top i wouldn't recommend luan.
1/4" is pretty thin, you could glue another layer everywhere the joystick is not.
