Author Topic: FS: NANAO 26" 15K-25K DUEL + PSU Video Amps Console Converters + More (MI)  (Read 1509 times)
northerngames
  • Trade Count: (+18)
Up for sale or possible trade is my current arcade monitor set-up I would like to sell or trade it as a set but I may consider breaking it down and selling the parts seperatly but I will not split any of it until the monitor itself is bought or traded first.
This is what the set has.
Nanao MS8-26SU 26" 15K-25K selectable res works great nothing goofy and all original.
Bob Roberts complete capkit I ordered this in case I had any troubles but never had any problems so this set is full and new still 30 caps total
big power supply with built in isolation transformer used to power monitor, marquee light, coin mech lights, gameboard, with plenty more outputs
smart strip power strip model# SCG4
Ultimarc VGA Video Amp this is a amp to make a cleaner brighter display when running a pc on a arcade monitor
www.arcadecabinets.co.uk dreamcast to 15K arcade monitor kit with built in video amp enables dreamcast to display amazingly on a 15K arcade monitor
DB-15 switchbox
VGA & DB-15 cables
 The way I have this set-up you just plug the vga cord into the pc and plug dremcast cord into the dreamcast and the other ends of them run to the switchbox's inputs and then the switch box's output cable goes to the monitor.
 So once everything is plugged in all that you need to do to swap between dreamcast and pc is flip the switch on the switchbox there is no tools or messing/swapping with wires needed to change between the dreamcast and pc this way.
 Only reason I am selling/trading this set is I want to get a monitor that can display higher res's that 15K arcade monitors cannot do.
 I am looking for cash or possible trade for a 24"-27" LCD screen or something around the size of the nanao's actual screen size display area like a regular vga crt 25"-27" my cab is 26-1/2" wide so it cannot be any wider then that.
 Located in michigan and would preffer it to be in person but if someone is intrested in buying it and having it shipped that would have to be arranged by the buyer I am willing to take it out to the curb to your shipping guy of choice.
  I dont have anything to pack and ship something like this and everything works great now and I would take no responsibilty for any of it if they break something before it made it to you that is why I would preffer a in person deal.
will post pics if needed.
northerngames
everything is still available.
northerngames
everything is still available but the monitor PSU and capkit are pending so if they sell I will be willing to part out the rest but the monitor still must go for sure first.
northerngames
 :o
