Author Topic: Build a patio how much crushed stone?  (Read 1494 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: March 20, 2008, 07:52:57 pm »
I am building a patio with pavers and it is going to be about 300 square feet.  The size is about 20 by 14 and the crushed stone base needs to be 6 inch's compacted.  I have been told I need anywhere from 7 tons to 10.5 tons anyone know what is correct?  I will be using 2A modified compacted stone.
I b**ch. People listen!!
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: Build a patio how much crushed stone?
« Reply #1 on: March 21, 2008, 09:47:21 am »
That sounds about right.  We did a 16 x 30 barn with pavers and we used 12 ton with 6 inch.  You should be able to use around 8 and it'll be real easy leveling.
Ed_McCarron
« Reply #2 on: March 21, 2008, 09:51:05 am »
http://www.aestone.com/calculators/aggregate.shtml
Comes up with 7.7 tons for 3/4" stone.  2A Modified is smaller, plus the crap they sweep out of the crusher, so it weighs a bit more per ft^3, I'd guess.
My parking lot is 2A modified.  It doesn't drain worth crap.
