Author Topic: arcade chassis  (Read 3836 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
arcade chassis
« on: March 17, 2008, 10:38:01 am »
where to get a good chassis to convert a 27 tv tube to arcade monitor
Ken Layton
  • Guru
  • Technician
Re: arcade chassis
« Reply #1 on: March 17, 2008, 12:18:40 pm »
Here:
http://home.earthlink.net/~arcadeparts/index.html  (sells the Wei-ya/Huai Electronics chassis)
http://alvaamusement.com  (sells the Wei-ya/Huai Electronics chassis)
www.8liners.com  Sells both the Jen Shinn and Wei-ya/Huai Electronics chassis)
alienware32
Re: arcade chassis
« Reply #2 on: March 17, 2008, 12:43:29 pm »
thanks for the info ken
Ken Layton
  • Guru
  • Technician
Re: arcade chassis
« Reply #3 on: March 17, 2008, 12:46:49 pm »
Just to note, all three of those companies are in Miami, Florida.
8liners.com just recently jacked up their shipping charges.
Alva Amusement has the lowest prices.
alienware32
Re: arcade chassis
« Reply #4 on: March 17, 2008, 01:30:47 pm »
ken can i use a regular videocard with the monitor if i use soft 15 or do you recommend i get a arcade vga
Ken Layton
  • Guru
  • Technician
Re: arcade chassis
« Reply #5 on: March 17, 2008, 05:15:09 pm »
Sorry can't help you there. My experience is with real arcade gameboards feeding the monitor a real arcade video signal.
alienware32
Re: arcade chassis
« Reply #6 on: March 18, 2008, 02:45:13 pm »
quick question ken when i get every thing hook up do i plug the power cord in a electric outlet or do the chassis need a islation transformer
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
Re: arcade chassis
« Reply #7 on: March 18, 2008, 04:46:38 pm »
isolation transformer
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
alienware32
Re: arcade chassis
« Reply #8 on: March 18, 2008, 05:53:16 pm »
the chassis that match my tube say it don't need a isolation transformer
grantspain
Re: arcade chassis
« Reply #9 on: March 18, 2008, 06:02:21 pm »
not all monitor require an iso transformer,if it says you don't need one then don't bother
alienware32
Re: arcade chassis
« Reply #10 on: March 18, 2008, 06:05:22 pm »
this is the chassis
grantspain
Re: arcade chassis
« Reply #11 on: March 18, 2008, 06:11:46 pm »
go for it bro,just make sure you have matched the yoke impedence and tube size otherwise you will get geometry issue's
alienware32
Re: arcade chassis
« Reply #12 on: March 18, 2008, 06:17:19 pm »
My vohms-7  my h ohms 2   the tv tube is a sanyo 27  will this chassis fill the entire screen because on the site it say it for a 25 inch monitor
« Last Edit: March 18, 2008, 06:19:50 pm by alienware32 »
grantspain
Re: arcade chassis
« Reply #13 on: March 18, 2008, 06:42:52 pm »
it should be o.k,its close enough.
most far east chassis have enough adjustments to counter act any geometry/size issues as long as the specs are close
alienware32
Re: arcade chassis
« Reply #14 on: March 18, 2008, 06:55:26 pm »
should i use a arcade vga or radeon 8500 with soft 15 and video amp
« Last Edit: March 18, 2008, 06:59:46 pm by alienware32 »
grantspain
Re: arcade chassis
« Reply #15 on: March 18, 2008, 07:01:29 pm »
always start with the cheap option,try soft 15k with a standard graphics card.if you are not happy then upgrade to a avga
stuff like this is always trial and error
alienware32
Re: arcade chassis
« Reply #16 on: March 18, 2008, 07:08:02 pm »
i try the radeon first but how do i connect it can i use ultimarc video amp to make it simple
grantspain
Re: arcade chassis
« Reply #17 on: March 18, 2008, 07:23:12 pm »
i am not sure as i do not mess with mame stuff BUT a cga monitor wants a 1.5 to 4 volt signal whereas a vga will supplying 0.7 v so my view is that you will need a signal amplifier
you could always just try connecting direct to see if you get a good enough picture,it won't do any harm
alienware32
Re: arcade chassis
« Reply #18 on: March 18, 2008, 07:28:26 pm »
i will email Andy he will know thank for you input
alienware32
Re: arcade chassis
« Reply #19 on: March 20, 2008, 11:36:04 pm »
 does anybody know what resolution the 8liners chassis can handle
Ken Layton
  • Guru
  • Technician
Re: arcade chassis
« Reply #20 on: March 21, 2008, 12:05:45 am »
The chassis sold by 8liners, Alva, etc. are all standard resolution.
alienware32
Re: arcade chassis
« Reply #21 on: March 21, 2008, 08:12:29 am »
what i meant is whats the max resolution it can handle like 640x480
« Last Edit: March 21, 2008, 11:02:50 am by alienware32 »
alienware32
Re: arcade chassis
« Reply #22 on: March 21, 2008, 04:24:02 pm »
what i meant is whats the max resolution it can handle like 640x480  i know it cga i just don't want to fry anything
