Author Topic: is 1/2 inch MDF enough for joystick build?  (Read 2867 times)
noobofthecentury
  • Last login:April 15, 2008, 01:18:00 am
« on: March 17, 2008, 02:11:30 am »
I keep reading that everyone uses 3/4 MDF for their arcade cabinets and joysticks.
The store near my home sells 1/2 inch thick MDF, will that cause problem?
I know this is a woodworking section but I just thought to throw this question,
how do u properly make a hole for a pushbutton in a plexiglass or lexan?
IA1NY
  • Last login:April 17, 2008, 06:32:20 pm
Re: is 1/2 inch MDF enough for joystick build?
« Reply #1 on: March 17, 2008, 07:14:57 am »
Use a hole saw for drilling holes in Plexi or Lexan.  Especially if you are new to carpentry.  Drill slowly and clear chips often.  You can also use mineral oil as a coolant/lubricant which makes the holes smoother.  Lexan is less brittle and stronger than plexi, thus more forgiving.  You can use a spade bit or Forstner bit on either, but there's more chance of cracking plexi if you use these.  The hole saw will seve you well.
  • Last login:Yesterday at 12:10:15 pm
« Reply #2 on: March 17, 2008, 11:18:05 am »
If you are planning to use through bolts to mount the joysticks then 1/2 MDF should be fine.  It's probably fine anyway with just screws from underneath too as long as you use like 8 of them.  Regular Happs buttons can be mounted in just about anything.
shardian
« Reply #3 on: March 17, 2008, 11:28:36 am »
So you are just building a desktop control panel? How big?
I built my single player desktop out of 1/4" material.
